Landing Flap Video
Old August 11th 11, 04:01 PM posted to rec.aviation.soaring
Tony[_5_]
Default Landing Flap Video
The biggest downside to flaps is that they are hard to train for,
since there are few two-seaters that have them. And too many gliders
that do have them (I'm looking at you, SGS 1-35), don't have enough of
them, so it's too easy to float down the runway. Flaps that go to only
60 degrees aren't enough; it takes at least 85 to reliably kill the
float and get onto the ground with authority.
Bob I've got to send you a picture of the NG-1 with full flaps out. In
fact I need to shoot some landings in it sometime and get some photos
of it from the ground. That thing is impressive! I'm pretty sure the
handle is limited to about 60 degrees or so but that is more than
enough flap. In fact it takes about all the strength in my left arm
to get that much flap at a typical 60 mph approach speed. The flaps
are the same as a BG-12/16 and run from the root to the aileron. On
the few full flap approaches i've done SeeYou has shown an L/D of
somewhere around 5.
Old August 11th 11, 04:28 PM posted to rec.aviation.soaring
Due to the lack of a "large span" trainer, Bob K developed the following
page to assist Schreder sailplane owners make the transition.
http://www.soaridaho.com/Schreder/St..._HP_flight.htm
Even though the page was designed for HPs, it applies to any flaps-only
sailplane.
Here are a couple other landing videos.
http://www.youtube.com/watch?v=BC55ikXmo5I
http://www.youtube.com/watch?v=19uZV4wH00
HP-14 "6F"
http://tinyurl.com/N990-6F
"Tony" wrote in message
somewhere around 5.
Old August 11th 11, 04:32 PM posted to rec.aviation.soaring
The second link should be
http://www.youtube.com/watch?v=19uZV4wH00U
"Wayne Paul" wrote in message
m...
sailplane.
HP-14 "6F"
somewhere around 5.
Old August 12th 11, 12:49 AM posted to rec.aviation.soaring
BobW
somewhere around 5.
Using crude distance measuring methodology (altimeter for vertical/paced-off
distance for horizontal), I eventually concluded the HP-14 I flew, achieved a
full-flap final-approach L/D, at 45 knots indicated, of somewhere between 3:1
and 1:1, the latter number being easily approached in even the lightest
headwind. I was simply curious, and didn't really care what the 'real' number
was, once it became (more or less instantly [happy memory!]) apparent that the
risk of undershooting in such an immensely 'approach capable' ship was
non-existent.
Nonetheless, despite the immense drag of that particular ship's
fully-deflected flaps, it remained possible for Joe Pilot to 'throw away'
some/all of the flaps' short-field landing capability by flaring 'too fast,'
in which case - as others have noted the possibility of doing - you *would*
float long and far in ground effect. I don't mean to suggest that every
flare/landing need/ought to be a low-energy affair, but if you're flying a
large-deflection-landing-flapped ship and routinely taking a longer distance
to flare, touchdown and roll-out than your buddies in otherwise similar
spoilered ships, you might want to continue learning how to safely extract the
unused landing performance that *does* reside in your ship.
Regards,
Bob W.
Old August 3rd 11, 02:56 AM posted to rec.aviation.soaring
Berry[_2_]
In article , BobW
Check out...
http://www.youtube.com/watch?v=PXwy7dsLndM
...for a nice/useful/short video of two flapped landings in an HP-14,
owned/flown/filmed by Wayne Paul (and posted here with his permission).
Curious reader-pilots may find the following information helpful, should they
Nice. Enjoyed the videos.
Had the distinct privilege of flying an HP-16 once (Thanks Dr. Jim). It
has the infamous "flaps and V-tail of death" that I had always heard
spell certain doom. In spite of the hype from know-it-alls who had never
actually flown with flaps or V-tails, I found the handling of the V-tail
was indistinguishable from that of a cruciform or T tail glider and the
flaps were just tremendous fun. In the pattern, I turned final at 600
feet and when the numbers disappeared under the nose I started rolling
in flaps. I kept on rolling in flaps until the numbers appeared again.
The horizon was way up the canopy at this point. Glanced at the airspeed
and it read 60 mph, so I rolled in a little more flap. I don't think I
ever actually reached the full 90 degree deflection. When the ground got
close enough that I could not stand it, I counted to three (quickly) and
flared. Touched down just past my aim point, slightly tail low, and
made a very short rollout. Not much different from landing an older
Cessna with big flaps and power off.
I think flaps for glidepath control on gliders got a bad rap because
some models of the Schweizer 1-35 had inadequate flap and were flown by
those who were not careful to control their speed on final.
Old August 3rd 11, 05:55 PM posted to rec.aviation.soaring
Dr Jim's HP-16 is beautiful!!
http://www.soaridaho.com/Schreder/HP...rst_Flight.htm
HP-14 "6F"
"Berry" wrote in message
In article , BobW
Check out...
they
Old August 10th 11, 06:19 AM posted to rec.aviation.soaring
Bruce Hoult
On Aug 2, 2:15*pm, BobW wrote:
As for the rollout, how many 1-26 drivers
routinely roll no more than 300 feet on a hard surface after touchdown? (And
how long does your skid plate last?)
I haven't flown one of those in anger, but most of my genuine landouts
have been in a PW5.
I always pace out the distances afterwards. The usual figures are
about 30 paces from a standard cattle farm fence to the main wheel
touchdown point, and another 30 paces to the point where I'm stopped.
If I call the paces 1m each then that's 200 feet -- from the fence,
not from touchdown.
Most of the rest of my landouts were in a Club Libelle. I'd say the
distances were quite similar. It, of course, has speed limiting
trailing edge airbrakes, which also have enough flap effect to lower
the stall by ~5 knots.
IMHO, large deflection landing flaps on gliders are the best kept sailplane
secret in the last half century.
I'd love to have some! But the trailing edge brakes as on the Club
Libelle, Hornet, Mosquito and I think also the Mini Nimbus and early
Ventus seem to give most of the same benefits, plus some extra ones.
Old August 12th 11, 12:58 AM posted to rec.aviation.soaring
BobW
have been in a PW5.
not from touchdown.
Pacing off - or otherwise striving to find some realistic method of
quantifying - one's landing rolls is a highly worthwhile activity, whether at
the gliderport (establishes one's required-field-length 'baseline'), or
eventually in fields (the field distance *will* be shorter due to the higher
drag of the unpaved surface). I usually found my 15-meter Zuni's off-field
rolls ranged from 150' to 200', probably averaging 180'. Field surfaces ranged
from plowed/disked/dry fields (my personal favorite) to hard-packed dirt
(occasionally) and reverting-to-prairie (once). The one G-102 (w. 2 aboard)
OFL I made in a plowed/disked/dry field, albeit very slightly downhill but
into a good breeze, paced out at 220'. All those distances are for summer
conditions at ~5,000' msl. They would've all been less at sea-level, I reckon.
And it's that stall-speed-lowering capability I so love about landing flaps
(and their close cousins found on some Glasflugel & Schempp-Hirth designs),
when it comes to reducing off-field roll-out risks!
Lacking any experience with those designs' 'flaplike' landing aids, I've
resorted to picking pilots' brains whenever I could, trying to get a handle on
the ships' drag-devices' pros & cons. One of my broad-brush, tentative,
conclusions eventually became few 'club-based' pilots ever really learned (or
strove to learn?) how to consistently extract the lowest energy touchdowns
from the devices. The conclusion was based on probing, trying to understand
the pilots' knowledge limits (both practical and theoretical), and then - when
I could - continuing to watch their landings.
FWIW, I routinely thought and flew as if the biggest 'unknown risk', directly
influence-able by me, in soaring was off-field landings, and - once committed
to a given field - the most pertinent thing I could do to minimize the
landing-surface-related 'unknowns risk' was to achieve as short a rollout as
safely possible. Hence the theoretical attraction to me of landing flaps.
Learning their 'unanticipated benefits' was pure gravy!
Regards,
Bob W.
Old August 12th 11, 02:24 AM posted to rec.aviation.soaring
Tony[_5_]
lower gross weight is also a great way to lower the stall speed and
shorten the ground roll. typical off field distances from first
impression in the dirt to stop is around 100 feet (30ish paces) in the
600 lb all up Cherokee. of course that light weight might also be
part of why I find yourself in fields so often...
Bob - found a couple of itty bitty tears in the fabric from the last
field at Dalhart. still way better than that piece of steel, which is
still riding in the bed of my pickup!
Old August 12th 11, 02:59 AM posted to rec.aviation.soaring
jim wynhoff
have been in a PW5.
not from touchdown.
Regards,
Bob W.
Since I know SOMEONE will call you on it..... It must have been pretty
cozy in the "G102 w/2 on board"! I assume that was a typo, and you
meant G103. G-102 (w. 2 aboard)
Not that I'll ever be able to afford a different glider, but I would
love to have a 'flap only' ship. Simpler (hence lighter) wing, shorter
roll -outs, etc. What's not to like?
Landing 16L KJAN Landing 17 KMBO - Video [email protected] Piloting 0 October 29th 09 01:12 AM
gear-up landing video on CNN [email protected] Owning 0 November 17th 05 11:54 PM
Here is Some video Of Landing In My 150 7676U NW_PILOT Owning 17 July 9th 04 05:10 AM
Here is Some video Of Landing In My 150 7676U NW_PILOT Piloting 15 July 8th 04 11:09 PM
Is there a mod to increase Nimbus 2 landing flap range goneill Soaring 1 April 15th 04 04:29 AM
