Auto conversion cost post
Old December 24th 03, 12:02 PM
George A. Graham
On Wed, 24 Dec 2003, Peter Dohm wrote:
Therefore, my most recent thinking is leave the engine completely stock,
including all harmonic balancing and damping components; and supply it with an
offset reduction drive. Just my 2 cents.
I agree Peter, I also used the stock 5spd transmission as a psru, but did
use a lighter flywheel.
Over five years flying, almost 400 hours, I love it!
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
Old December 25th 03, 10:03 PM
Ben Haas
So George, fill us all in on how you took a 5 speed trans and used it
to transmit 500-600 pounds of thrust from the prop when in a car there
is no thrust loads on the output shaft at all??
George A. Graham" wrote in message ...
George Graham
Old December 27th 03, 01:03 PM
George A. Graham
Sure Ben, Single deep groove bearings, and it is more like 300 lbs.
The stock output shaft is not used (too long).
George Graham
Old December 27th 03, 10:42 PM
Ernest Christley
George Graham
George, the last I heard, you had some teething pains with that
transmission PSRU and got some busted gears. I have to assume that is
all cleared up, but what is a 'single deep groove bearing'?
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Aircraft per hour cost Fitzair4 Home Built 0 December 1st 03 02:15 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
