Found Loose Cylinder Bolt
Old February 17th 04, 12:49 PM
Paul Sengupta
"Orval Fairbairn" wrote in message
news ...
Tightening sequence: (1/2" first)
This is something I was thinking of. What happens if one comes loose?
Should you just tighten it to thee correct torque, or should the others be
loosened then all tightened in sequence? Maybe even replacing the
gasket? (don't know about gaskets...I would only guess as to the
presence of one)
Paul
Old February 18th 04, 12:46 AM
Dan Thomas
"Paul Sengupta" wrote in message . ..
news ..
presence of one)
Paul
Some of those nuts are on studs that pass through the case to hold
it together and to keep the main bearings tight in their bores. A
loosened stud could allow the bearing to rotate a bit if it didn't
have a locating pin in it. Can't remember if the O-200 has one. I know
that the Lycs do. I've seen a centre main rotate in an O-200 while the
cylinders were off and someone rotated the prop. Everything jammed
real tight when we retorqued it.
Rotated bearings cut off their oil supply ports and don't last
long.
Dan
Old February 18th 04, 02:02 AM
Greg Hopp
gasket?
Paul
Paul:
The first mech. I talked to was adamant. It was his butt on the line
liability wise, and if I wanted him to do the job, he was going to
break all the nuts and retorque everything, estimating 8-10 hrs labor.
He also mentioned a "one time seal" that would then likely be a leak
candidate as a result, but he wasn't going to do it any other way.
Greg H.
Cols., OH
"First timer, always learning"
Old February 18th 04, 05:46 AM
John
Your first mechanic is an idiot but he is going to give you the shaft
for HIS error.
There is some difference in the break away torque of a bolt that has
sat with a preload on it and one that you are tightening to a
specified torque. It takes MORE torque than that specified to start
the nut turning if that nut has sat with a preload for more than a
second. You can be assured that if the nut turns when the specified
torque is applied then it is NOT torqued to the specified amount and
needs to be loosened and retorqued.
The most common cause of cylinder bolts getting loose is PAINT or dirt
under the cylinder flange.
These bolts are critical and must have the required torque.
If you loosen only one nut at a time you should not have to replace
the seal but if you loosen all of the nuts at the same time then there
is a good chance that it will leak because the cylinder will move.
gasket?
Paul
Paul:
Greg H.
Cols., OH
Old February 17th 04, 01:34 PM
Dennis O'Connor
90% of engineering is common sense and only 10% is an incredibly complex
science... Luckily the first 90% is what keeps common machines running, and
that last 10% is reserved for machinery like the space shuttle, mars
explorer, etc..
denny
The gents hanging out at the
FBO say, put a wrench on her and fly the darn thing.
Old February 17th 04, 05:49 PM
Greg Hopp
Orval Fairbairn wrote in message:
According to my Lycomung Overhaul Manual, the cylinder torque settings
a
Thanks for your help Orval. We're going to the hangar tomorrow night
with a borrowed torque wrench for some testing.
Greg H.
Cols, OH
Old February 17th 04, 05:48 PM
Greg Hopp
Tina Marie wrote in message ...
With that said, you have two choices he
A) Put a torque wrench on it, tighten it and then fly it. Torque
settings are in the Lycoming Direct Drive Overhaul Manual (~$17 for a
reprint from Aircraft Spruce, or find the equivalent Continental
publication). Check it every few hours.
B) Take it to your A&P. He will pull out his torque wrench, his copy
of the Lycoming Direct Drive Overhaul Manual, tighen it, and tell you
to check it every few hours.
It's up to you.
Tina Marie
Tripacer N3653P
The on-field mechanic says, from a liability standpoint, he's going to
crack and retorque each and every nut on all four jugs. 8-10 hrs
labor. Another (off field) mechanic says, if the nut won't tighten,
we're into a whole different issue wherein the case will need to be
split, sent out and the threads repaired (helicoil?) inside the case.
Now, what is otherwise a simple job costs a couple grand for the labor
alone.
Greg H.
Cols, OH
Could the Press Grow a Spine? WalterM140 Military Aviation 259 July 11th 04 08:35 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 08:11 PM
Maybe GWB isn't lying........ JD Naval Aviation 9 February 21st 04 12:41 PM
Air Force wife, kids found dead Otis Willie Military Aviation 0 July 19th 03 04:36 AM
