#11
Ok Roger, Thanks. I'll see if we can get together soon to check that
out. How do you check the cam-- pull the rocker arms, pushrods, and lifters, and peek into the hole where the lifters were? Thanks, John Clonts Temple, Texas N7NZ "Roger Long" om wrote in message . .. I repeat. Make that next flight after the entire valve train has been checked. Just the broken spring could have caused other damage that will come back to bite you. I've been talking to another guy who had the lifters in his 210 go bad just under 700 hours even without any broken valve springs. The cam shaft is driven directly by the engine and, when things go wrong in the rather delicate valve train, all that power can really screw things up. -- Roger Long John Clonts wrote in message m... "Jay Honeck" wrote in message news:pygZb.224397$U%5.1418539@attbi_s03... Thanks for the replies. It WAS the fuel injector, which was blocked. Good deal, John. Any idea what caused the clogged injector? Bad gas? Good question! My mechanic posited that the broken valve spring somehow facilitated the clogging of the injector. I'm not sure I can see that... Also, it's kinda hard to resolve the "intermittent" nature of the problem from flight to flight beginning a month or so ago, i.e. "When did the valve spring break?", and "When did the injector clog-- and was it suddenly, or gradually?". I will be pondering these things during my next few flights! Cheers, John Clonts Temple, Texas N7NZ |
Speaking of which, Jay... did you ever swap your Grape's fuel filter and
cut open the old one? I ended up rigging a funky plumbing concoction with water-absorbing spin-on filter for refueling from 6 gallon cans. I swapped the fuel filter -- but it was too danged cold at the hangar to cut the thing open. Next one is due to be swapped soon. With the warmer weather, I'll cut this one, although I don't expect to find much. (Pretty new tank on the Grape plus brand new tank at the gas station should -- I hope -- equal pretty clean gas...) It'll be interesting to see what is being caught. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
: It'll be interesting to see what is being caught. That's why I rigged in my filter. Before that, I always saw a very small amount of brownish water (about 1/4 teaspoon) in each tank on every sump check. Also trace amounts of very fine flakes (rust?). I *never* saw any of it that made it into the gascolator. Now with the water-absorbing filter spout, I only get a trace amount of water if it's condensed in the tanks (if not flown for a few weeks). No debris at all. Much more reassuring. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
"Jay Honeck" writes:
Next one is due to be swapped soon. With the warmer weather, I'll cut this one, although I don't expect to find much. (Pretty new tank on the Grape plus brand new tank at the gas station should -- I hope -- equal pretty clean gas...) ROTFL.... The dirt arrives in the tanker just the way the gas does.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
John Clonts wrote:
Thanks for the replies. It WAS the fuel injector, which was blocked. Man, did you dodge a bullet. Congrats. Last week, I finally got my Comanche back from maintenance, and what started out as an annual last July, with the engine seeming to run fine. It turned into a major overhaul, when it was discovered that my #5 cylinder had problems, and it turned out the cam lobes were worn past airworthiness. Labor to correct that was equal to labor to major. I majored. It's a crapshoot. |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
rough engine just after power reduction | Sydney Hoeltzli | Owning | 11 | July 30th 03 03:37 PM |
First Emergency (Long Post) | [email protected] | Owning | 14 | July 23rd 03 02:46 AM |
