#5 cylinder not firing
Old February 26th 04, 04:32 PM
David
Update: Our mechanic found a bad spark plug lead wire. Thanks for all of
the replys.
"David R." wrote in message
We have a 1979 Cessna 182RG with 1350 hours since overhaul. 6 weeks ago,
we began to notice the engine to be rough on the right magneto during
run-up. Over two weeks, it became increasingly difficult to burn it off
by
leaning during the run-up, until one day when it became impossible. We
noticed on the engine monitor that the #5 cylinder head temp was cold
during
the run-up. Our mechanic looked at it, and yep, it was a fouled spark
plug
which was replaced. Now, about 15 hours later (and an annual), we have
same problem with the #5 cylinder. It's going back to the shop today.
Any
ideas? Why the same cylinder? What should we be looking for?
Old February 26th 04, 10:11 PM
Kevin Chandler
I have no idea. I did not do it. The A&P made the call and got it right.
A new/used jug fixed it all.
How do you diagnose a cracked piston ring? Scope? Compressions?
"Kevin Chandler" wrote in message
We had a similar problem except the plug was getting fouled with oil.
We
had a crack piston ring.
Old February 27th 04, 12:30 AM
G.R. Patterson III
A cracked compression ring will show up as low compression. A cracked oil wiper
ring will show up in fouled plugs, oily deposits on the inside of the exhaust
pipes, and smoky exhaust.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
Old February 27th 04, 12:41 PM
Dennis O'Connor
And a cracked wallet will show up soon after..
denny
"G.R. Patterson III" wrote in message
wiper
exhaust
George Patterson
that
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 08:11 PM
O-200 Cylinder Repair jls Home Built 3 February 29th 04 02:45 AM
Cylinder Wrenches for 0-320A Narrow Deck DAVE Home Built 1 December 31st 03 01:45 PM
Stick Shake When Firing Guns John Kunkel Military Aviation 17 October 2nd 03 12:39 AM
'Hot' cylinder after overhaul? Tony Cox Owning 8 August 10th 03 07:25 PM
