Water ballast rookie question
Old August 18th 11, 03:05 PM posted to rec.aviation.soaring
mattm[_2_]
Default Water ballast rookie question
On Aug 18, 9:09*am, JJ Sinclair wrote:
On Aug 17, 11:13*pm, P9 wrote:
Another water ballast question.
How well does a fully ballasted glider recover from a spin?
I practice spins every season, dry. *The recovery is easy and
predictable. *(SZD 55-1) *I have never tried a spin with water. *If I
accidently spin at low atlitude (1000 ft agl or lower) fully
ballasted, should I attempt to recover, or just bail?
Kerry
Hi Kerry,
Enjoyed flying with you at Air Sailing Sports. Good race again this
year and those AFA guys can no longer be ignored, can they?Your 55
holds a ton of water, I'd recommend you try spinning it with a half
load, then work up from there.................well maybe that's not
such a good idea because a partial load can shift to the outboard wing
tip and give a big lateral weight problem. I remember Carl Herold
telling me the 12 would tuck under to where the nose was more than
vertical when he spun her with a load of water.........Hmmm, maybe
don't spin it wet would be the best advice and if you spin it at 1000
agl, i'd do it with *a BRS installed. Adding the BRS to my Genesis was
the best thing I have done lately, I feel much more secure now and
enjoy that comfortable seat (without *chute).
Cheers,
JJ
Don't forget the story of spin testing the Schweitzer 1-35. Since the
plane was to be certified by the FAA and it was the first Schweitzer
with water ballast, the FAA insisted on a spin test with one wing full
and the other dry. Needless to say it was a pretty exciting test...
The towpilot followed the plane down and reported the spin axis was
outboard in the wing. It took multiple kicks of the rudder to finally
break the spin.
The test pilot administered a few extra kicks after landing just for
good
measure!
Note also that some planes prohibit spins while loaded with ballast.
Make sure to consult your owner's manual carefully. Keep in mind
that the ballast will move outboard in your wings and increase your
rotational momentum. Also keep in mind the advice from a good
friend of mine who used to be a test pilot: "Don't spin!"
-- Matt
Old August 18th 11, 04:34 PM posted to rec.aviation.soaring
Mike the Strike
Kerry
Hi Kerry,
Cheers,
JJ
Don't forget the story of spin testing the Schweitzer 1-35. *Since the
and the other dry. *Needless to say it was a pretty exciting test...
outboard in the wing. *It took multiple kicks of the rudder to finally
break the spin.
good
measure!
Make sure to consult your owner's manual carefully. *Keep in mind
rotational momentum. *Also keep in mind the advice from a good
friend of mine who used to be a test pilot: *"Don't spin!"
-- Matt
Some years ago, I got kicked out of a boisterous and very turbulent
Arizona thermal flying my ASW-20 with close to full ballast. The yaw
string went sideways, then backwards and I literally fell out of the
sky, entering a strong incipient spin (perhaps half or three-quarters
of a turn). I fortunately did everything right and recovered quite
quickly, but lost nearly 800 feet of altitude in the process. It
caught my attention!
Ever since then, I have always thermalled more conservatively when
anywhere near the ground. I know of at least one incident of a modern
ship that stalled off tow and spun into the ground when fully
ballasted.
I also do not spin - ever!
Trying for a Diamond Goal tommorow - water ballast question Scott Alexander[_2_] Soaring 27 April 29th 10 09:28 PM
DUMB ROOKIE QUESTION Travis Beach Soaring 10 November 7th 06 07:28 PM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
