![]() "Tom Sixkiller" wrote in message ... " jls" wrote in message ... Not simple. Questions abound: depending on type engine, type induction, whether turbocharged, field altitude, density altitude, formula gasoline (Some people love autogas), and much more. For example if your plugs aren't gapped correctly you're going to have a serious problem sooner or later. I saw an O-235's plugs recently and couldn't believe the lead deposits and fouling. Don't know if they were gapped properly but the spaces inside the plugs between the ceramic and the inside diameter of the plugs were filled with hard gray deposits. http://www.avweb.com/news/columns/182155-1.html (About half way down the page). Excellent reading. Thanks, Tom. I agree that concentricity of valves and seats is critical and that valve face to seat contact must be broad and precise. There are many more factors to contend with too. Such as how much cooling oil flows across the stems, springs, keepers, and guides in the rocker boxes and then flows down the pushrod tubes with this heat. Such as how much pressure air flows across the fins on the exhaust port side of the cylinder, and is there enough fin surface area there? (O-200 Continental cylinders have always been hot on the exhaust port side because of too little fin area.) Are the cylinder baffles and cowling and cowling seals doing their jobs? Sparkplugs carry away destructive heat too and so do pistons. I am looking at a set of webbed pistons which are designed for splash oil cooling. Are the pistons and the sparkplugs doing their part? Is the exhaust system tuned for optimum scavenging of hot exhaust gases? There's a repair station in Berryville, Arkansas which specializes in Nascar-style valve jobs. In an e-mail from Seth Record* he says they balance, port and polish, flow match, and precision fit the valves, seats and guides for concentricity. He says their cylinders will make it to TBO. Most don't, of course, and usually die before making 1,000 hours. I haven't seen any of PAP's work but am eager to try some of their cylinders. They install the guide undersized and hone, not ream, it to fit, which gives the valve a slicker bearing. Then they grind 3-angle seats. Fascinating. I'd love to hear from anyone with experience with these cylinders. Publish it here in RAO. *A couple of us are about to buy some cylinders from Seth at the moment. The company advertises in Barnstormers and other sites as Performance Aircraft Parts. |
jls wrote:
Not simple. Questions abound: depending on type engine, type induction, whether turbocharged, field altitude, density altitude, formula gasoline (Some people love autogas), and much more. etc, etc, etc............... Is there a question here? |
