Arrow auto gear extension oddness
Old March 3rd 04, 08:47 PM
Aaron Coolidge
James M. Knox wrote:
snip
: It doesn't take MUCH movement of the gear door to be enough to let one of
: those little microswitches come on (they are notorious for not going off
: even with the gear up - and get adjusted and adjusted, until they break).
: That far back (where the gear doors are) is probably a lower pressure area
: (try to close the cabin door in flight some time G) and the extra speed
: pulled it out a few millimeters.
The landing gear doors aren't directly actuated by the hydraulic system;
there is a mechanical linkage to the nose gear. The last couple inches of
travel pulls the nose gear doors closed. As you say, a very small amount
of downward creep of the nose gear will cause the gear doors to open a
considerable amount. Add the low pressure area trying to pull the doors open
to a tiny leak in the actuating clyinder and you'll see just this phenomenon.
: Another likely factor... this is an older Arrow 180. They came with 1400
: PSI switches. The 1400 PSI system was marginal. Newer ones came with 1700
: PSI, which held the gear doors shut better (and for longer periods of
: time). Many (but not all) have been upgraded, but we don't know if this
: one has.
Ah, I did not realize that.
Aaron Coolidge (N9376J)
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 06:19 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
