Importing an airplane is not trivial. First of all, no one will
finance it, so you can forget using it as collateral. This is BEFORE it is imported. Once you get it US registered this is no longer true. Then you have to have it inspected. If it has had any modifications that are not USA approved (like a Canadian STC that is not an STC in the USA), you have to fix that. All of this has to be done by a DER, an IA wont do. It helps if the airplane was originally certified as a USA aircraft. You also have to repaint the N Numbers. A rough estimate is that it takes about $10,000 to inspect, deliver, re-certify, paint and whatever else you run into. But you never know how much it will cost, could be less, could be more. In your case, Argentina is a long way away. Expensive and risky delivery. For a while they were importing aircraft from South Africa. You could buy a Baron for 1/2 the price of a USA one. Canadian 185's seem to go for about $20K less than US ones. So it can make sense. The less expensive the aircraft, the lesss sense it makes. Proabably just as expensive to import a 200k aircraft as a 50k one. If I were to import one, I'd call a big dealer in Canada and see if I could get the name of a USA DER that specializes in these issues. Talk to him and see how much it would cost. I suspect there are some near the Canadian border. |
Grumman FAAV? | Charles Gray | Military Aviation | 1 | July 19th 04 06:55 AM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Looking for info on Flyins | Chris Whitley | Home Built | 21 | February 11th 04 09:21 PM |
150HP Grumman Super Yankee FS Price Reduced! | Bill Berle | Home Built | 6 | December 2nd 03 12:55 AM |
150HP Grumman Super Yankee FS Price Reduced! | Bill Berle | Aviation Marketplace | 5 | December 2nd 03 12:55 AM |
