SAFETY ALERT
Old August 23rd 11, 01:50 AM posted to rec.aviation.soaring
Cookie
Default SAFETY ALERT
On Aug 22, 8:33*pm, Ramy wrote:
On Aug 22, 5:19*pm, Cookie wrote:
On Aug 22, 9:44*am, JJ Sinclair wrote:
OK Cookie, you don't like my Safety Alert idea. What actions would you
take to counter the recent rash of soaring accidents?
JJ
Well I can't counter the recent rash of accidents because they have
already happened......unless I get a time machine.
But I can point out actions to prevent pilots form repeting those
errors. *Most pilots are already doing preventitive measures, which is
simply a part of being a pilot and taking responsibility.
So lets take the recent incidents one by one, starting with the "low
pass" incident.
Solution: Don't do low passes!
JJ, that is the short answer and sums it up....and insures 100%
accident free due to low passes.....
If you don't understand this answer....I can give you the long version
if you wish. *Or we *can move on the another incident...
Cookie
Cookie, isn't this exactly what JJ was suggesting?? Reminding people
the dangers of low pass so they will avoid doing this?
Same goes for the rudder signal, low rope break etc. Remind people the
risks and consequences so hopefully someone else will avoid the same
mistake. There are still many pilots out there who live under a rock
and believe that soaring is safer than driving to the airport.
The SSF and the rest of us should discuss accidents so we all try to
learn something and remind ourself of the many ways we can kill
ourself.
Ramy- Hide quoted text -
- Show quoted text -
Ramy do you really need "reminding" to realize that low passes are
dangerous?
So a guy gets killed doing a low pass....Do you need the SSA, FAA,
NTSB, and whoever else to tell you "Don't do that".
I mean really, we are supposedly trained, experienced pilots..with
some degree of intellegence and common sense.
Cookie
Old August 23rd 11, 02:12 AM posted to rec.aviation.soaring
Ramy
JJ
pass" incident.
Cookie
ourself.
dangerous?
So a guy gets killed doing a low pass....Do you need the SSA, *FAA,
Cookie- Hide quoted text -
Yes, I need a reminder of what can go wrong (such as missinterpreting
tow plane signal), and so do most people, but espcially those who dont
read RAS, don't subscribe to any discussion group, live under a rock
as far as what is going on in the soaring world, and all they know
about soaring is what their instructor tell them and maybe what they
read in the soaring magazine. Many of them truely believe that soaring
is safer than driving to the airport, so what could possibly go wrong?
I know many such pilots, and I admit I was one of them when I started
soaring way back then. I was truely shocked the first time I heard
about a fatality.
Ramy
Old August 23rd 11, 03:02 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
dangerous?
It's not obvious to me the low pass was the cause of the Idaho fatality,
and given the cursory investigation the FAA can afford, we might never
know. Was it
* a medical problem
* a mechanical failure
* hypoxia
* malfunctioning airspeed indicator
* pilot incompetence with pattern turns
I'm sure others can think of more factors that would have led to
spinning in, even if the pilot did not do a low pass beforehand. And
that is part of the problem with the SSA coming out with "generic"
advice immediately after an accident: it may completely miss the cause,
and lull us into an unfounded complacency.
Cookie and others suggest "Don't do low passes", but that's generic
advice not yet supported by this accident. That advice can stand on it's
own without this accident. We should still strive to understand this
accident, though it will be difficult, instead of assuming it was just a
botched low pass.
We can't do a full investigation ourselves, but we can at least consider
those factors I mentioned. Can we rule out a medical problem? Will
someone inspect the glider for mechanical malfunction? Did he have
oxygen left in the tank, a functioning delivery system, an oximeter,
experience in using oxygen? Is the airspeed system potentially
over-reading? Could he always fly a good pattern, or did he
over-rudder/under-bank at times? Was his glider (HIS glider, not BG's in
general) well tested and benign (no surprises) in it's handling?
There are many ways for things to go wrong, and even after 35 years of
"trying", I still - more infrequently now - discover new ones.
email me)
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old August 23rd 11, 03:04 AM posted to rec.aviation.soaring
Mike Schumann
On 8/22/2011 7:50 PM, Cookie wrote:
On Aug 22, 8:33 pm, wrote:
JJ
errors. Most pilots are already doing preventitive measures, which is
pass" incident.
if you wish. Or we can move on the another incident...
Cookie
ourself.
dangerous?
Cookie
Obviously some us are not properly trained or don't have a certain
degree of intelligence or common sense. Some of these people might see
the light with a timely reminder. Many won't.
Also some fellow club members might wake up to the fact that one of
these days one of these stunts is going to involve an innocent
bystander. A reminder might motivate them to speak up and establish
some local common sense.
It might not help, but how can reminding people of the obvious hurt?
Mike Schumann
Old August 23rd 11, 03:32 AM posted to rec.aviation.soaring
Cookie
On Aug 22, 10:04*pm, Mike Schumann
On Aug 22, 8:33 pm, *wrote:
JJ
pass" incident.
Cookie
ourself.
dangerous?
Cookie
degree of intelligence or common sense. *Some of these people might see
the light with a timely reminder. *Many won't.
bystander. *A reminder might motivate them to speak up and establish
Mike Schumann- Hide quoted text -
Mike,
If there are that many stupid people out there flying (and I am
starting to think there are)..accident rates will not get better. I
think statistics show that accident rates for glider have been fairly
constant in the long run, with some good years and some bad years.
I "remind" myself...every time I fly, and even when I'm not flying.
If others need reminding, of the blatently obvious...OK remind them.
But my objection is to the knee jerk reaction to a fatality, and then
placing the blame other then where it belongs....
"If only the SSA would have released a safety bulletin then joe pilot
would not be dead"
Every club I know of has a "safety officer"...every club has "safety
meetings"...every club I know of has a "safety' section at the club
meetings....every instructor I know has a #1 concern for
safety...every gliding textbook I have ever read deals with safety to
some degree....every flight review is centered on safety....every
field check out is safety oriented....every prospective new club
member is examined as to safety....the SAA has published a safety
column as long as I can remember....NTSB publishes accident
reports...any number of pilot publications have an accident report
section and numerous safety articles....numerous books have been
published dealing specifically with soaring safety and accident
prevention......etc.
OK, so now we need "safety alerts"...go for it ...you're right it
couldn't hurt..........but will it address the problem? I dunno!
Cookie
Old August 23rd 11, 03:48 AM posted to rec.aviation.soaring
Cookie
dangerous?
know. Was it
* a medical problem
* hypoxia
botched low pass.
email me)
Eric,
I am not trying to say what actually happened in any of these recent
accidents...we are just talking about accidents in general..that there
are certain categories of accident that seem to repete...and how to
help prevent them.
* a medical problem
* hypoxia
You give 5 possible potential "causes" for accidents......we can
easily address each...and figure out how each of us could improve our
odds, or prevent the accidents caused by them.
I'm going to start with "malfunctioning airspeed indicator"........A
glider pilot should be able to fly safely without reference to an
airspeed indicator.......I can think of no accident where the cause
should be a malfunctioning airspeed indicator..airspeed indicator does
not seem to be a factor in any of the recent accidents.
Mechanical failure is very very rare..(unless caused by improper
flying)...annual inspections, 100 hour inspections and preflight
inspections insure us against mechanical failure.....the onus falls on
the PIC to insure the aircraft is airworthy. I don't see where
mechanical failure enters into any of the recent accidents.
Hypoxia is a good one.........we all should have received some degree
of training about hypoxia, its symptoms, and effects.
Many of us fly where this is seldon a concern..others use O2 on a
regular basis and better be proficient on this topic.
Again...don't see this relating to any of the recent accidents...
Medical problems.....we supposedly "self certify" and are required to
not fly during peroids of medical defeciency...does everybody do this?
Lastly pilot incompetence...........BINGO! That's the one! I
see this in accident after accident!
Cookie
Old August 23rd 11, 04:33 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
dangerous?
know. Was it
* a medical problem
* hypoxia
botched low pass.
email me)
Eric,
help prevent them.
* a medical problem
* hypoxia
The pilot flies through virga; water enters the airspeed system, causing
it to over-read as he pulls up from his low pass. As he waits for the
airspeed to bleed off to pattern speed while pointed up at 20 degrees,
the glider stalls and spins. This was my first thought, because I
recently had a virga induced airspeed error - my very first, despite
flying through virga and rain several times a year over 35 years of
glider flying. It took me at least a minute to realize I had a problem,
and even longer to decide it was water from the virga.
A control rod jams when you try to put the nose down, stall, spin - It's
not something even a person watching on the ground would see, much less
trying to dissect the cause remotely after the fact. I had a control rod
break in the club Blanik that was not inspectable by the PIC. We got
down safely. If we'd spun in, would inspecting the wreck have found
that? Maybe, maybe not. It happens.
King Mountain Glider Park (the Idaho fatality location) is at 5500';
cloud base on a good day can be 20,000'; 16,000' to 18,000' is normal
for August. We don't know how high he was or for how long, how well his
oxygen system worked, what his pulmonary condition was, and if he
monitored it.
We're not always aware of our medical deficiencies, or may misjudge
their effect.
But it shouldn't become a prejudice, or we won't learn from an accident.
email me)
Old August 23rd 11, 04:36 AM posted to rec.aviation.soaring
T8
On Aug 22, 10:32*pm, Cookie wrote:
OK, *so *now we need "safety alerts"...go for it ...you're right it
couldn't hurt..........but will it address the problem? *I dunno!
You know the answer as well as I do.
I started writing up "Safety Alerts" for the wrecks I've seen the
aftermath of in the last ten years and it read like it belonged in the
Onion. I'm lucky. None of these have been fatal.
-Evan Ludeman / T8
Old August 23rd 11, 04:47 AM posted to rec.aviation.soaring
Bill D
On Aug 22, 7:59*pm, Mike Schumann
On 8/21/2011 4:15 PM, wrote:
Personally I want the SSA lobbying against rules not making up new
ones or reminding me of old ones. * When advocacy organizations become
governing/safetycratic they are ruined, worse than useless. *Let the
SSA keep the gov't at bay, pilots, clubs, and insurance companies can
sort the safety standards.
I don't see a whole lot of lobbying going on either. *For whatever
reason, there seems to be ZERO interest at the SSA to involve new people
in the organization who have new ideas and are volunteering to help out.
Another example of a HUGE problem.
Mike Schumann
I have to strongly disagree on all points. The SSA welcomes
volunteers - there just aren't many of them.
The SSA has successfully lobbied for numerous FAR changes - expanding
the use of tow pilots with a private rating is just the most recent.
Before that there was the extension of parachute repack to 180 days.
The SSA cares very much about what is happening to members.
Bill Daniels
SSA Growth and Development Committee Chairman.
NTSB Safety Alert CH 601 Brian Whatcott Home Built 15 April 21st 09 05:36 PM
Klewless newbie alert! (Was Troll alert! Why is "CovvTseTung" using multiple aliases here?) Maxwell[_2_] Piloting 76 August 22nd 08 04:07 PM
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 [email protected] Soaring 0 November 8th 07 11:15 PM
Find a Safety Pilot in your area with Safety Pilot Club Safety Pilot Club Instrument Flight Rules 0 December 29th 06 03:51 AM
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA [email protected] Soaring 0 September 11th 06 03:48 AM
