Air extractors for Ventus 2?
Old August 25th 11, 06:37 PM posted to rec.aviation.soaring
johngalloway[_2_]
Default Air extractors for Ventus 2?
On Aug 25, 4:31*am, Tim Taylor wrote:
On Aug 24, 9:09*pm, jim wynhoff wrote:
On Aug 21, 7:35*pm, Tim Taylor wrote:
Are there any working designs for an air extractor for the Ventus 2?
Tim,
* Sisu1A *on RAS makes extractors for the ASW20 (some models), and has
made one (or more) for his SZD. In both of those cases, the extractor
replaces an access panel or hatch that happens to be in a position
that is 'good enough'. *I made a simple 'Mandl Extracor' for my Speed
Astirhttp://griderpirate.smugmug.com/Airplanes/Glider-stuff/3702283_Rsct24...
and it does increase cockpit comfort significantly.
Does the Ventus have a conveniently placed access hatch, or will there
be cutting involved?
Cheers,
Jim,
There will be cutting involved and most Schempp-Hirth's are Standard
Airworthiness. *I am looking at something similar to the Jonker's
design for my Ventus 2 to improve the airflow and cooling in the
cockpit.
Tim
http://www.easternsailplane.com/east...lplane/TheVent
Couldn't fit that legally in Europe nowadays
John Galloway
Old August 29th 11, 01:56 PM posted to rec.aviation.soaring
Tim,
Cheers,
Jim,
cockpit.
Tim
http://www.easternsailplane.com/east...ternSailplane/...
John Galloway- Hide quoted text -
- Show quoted text -
I would appear that you are not up to date with respect to ongoing
developments. EASA approval is very close for Schleicher gliders that
this vent was originally designed for.
UH
Old August 29th 11, 09:45 PM posted to rec.aviation.soaring
Sven[_2_]
Tim,
Cheers,
Jim,
cockpit.
Tim
UH- Hide quoted text -
I had the Eastern Sailplanes vent installed in my ASW27 and i have
little doubt that it is the single most cost-effective performance
improvement expense imaginable. I highly recommend it.
Sven Olivier
Old August 29th 11, 11:22 PM posted to rec.aviation.soaring
Andy[_1_]
Sven Olivier- Hide quoted text -
What performance gain did you see?
Is the US handicap guru, or contest committee, considering adding
extractors to the list of mods that require a contest handicap
change?
Andy
Old August 30th 11, 02:01 AM posted to rec.aviation.soaring
Brad[_2_]
On Aug 25, 7:52*am, Grider Pirate wrote:
On Aug 25, 7:47*am, Bob Kuykendall wrote:
On Aug 24, 9:21*pm, guy wrote:
...Then, I bought the Butler vent and had it installed. *It is installed
on the top of fuselage just behind the canopy. *WOW. *I can feel air
moving past my ears while flying...
Huh. So, exhausting air into the low pressure area above the wings
works better than trying to exhaust it into the high pressure area
below the wings. Who'd'a thunk it?
Thanks, Bob K.
Ahh, the mysteries of life..... ;-P
I had to build my own glider just to install a top mounted Mandle
vent............
Old October 9th 14, 02:16 PM posted to rec.aviation.soaring
Lucas[_2_]
Hello Tim,
have you come up to a conclusion regarding the air extractor for the Ventus 2 ?
Regards
Lucas
Old October 9th 14, 03:06 PM posted to rec.aviation.soaring
Old thread, new nickname for the Vent
"Fart Scoop!"
8-)
Old November 3rd 14, 08:48 PM posted to rec.aviation.soaring
Le lundi 22 août 2011 04:35:12 UTC+2, Tim Taylor a écrit*:
I installed one on my Ventus cM on the small engine bay doors. Works nicely..
Old February 15th 17, 03:49 PM posted to rec.aviation.soaring
@Tango Whiskey: could you share a pic of your installation?
Old February 15th 17, 04:51 PM posted to rec.aviation.soaring
Tango Whisky
Le mercredi 15 février 2017 16:49:13 UTC+1, a écritÂ*:
As I'm too stupid to include pics here, I've sent you a PM. BTW, I don't read emails on my gmail account ;-)
Cheers
Bert
FS Ventus 2cx 15/18 SAM AND LEIGH ZIMMERMAN Soaring 0 April 29th 08 02:10 PM
FS: Ventus C James Hamilton Soaring 0 September 13th 06 09:18 PM
FS: Ventus C 17.6 John Shelton Soaring 0 November 16th 04 12:55 AM
FS: Ventus C 17.6 John Shelton Soaring 2 November 16th 04 12:53 AM
FS Ventus C 17.6 John Shelton Soaring 0 August 18th 04 03:39 PM
