Paul... looks like your going to get the best price at $15K...
as stated before.. you could be lucky with the engine.. or not.. set up a deposit.. offer a free oil change and go get it checked if it comes back clean... that's good for today.. as an owner.. you will always need to be prepared for a complete engine overhaul BT "Paul Folbrecht" wrote in message k.net... I'm sure you will get responses saying not to worry. Those will be from others who have similar numbers and have not (yet) had a problem. Yes. Engines can be run well past TBO IF they are "overflown". For example, an engine run for 100 hours per MONTH (a.k.a. "trainer") can get 3000+ hours before going downhill. The one in question got 40 hours a YEAR. I suspect the reason some consider a plane like this is because it is close by, or because they don't have the cash to get one with better numbers. In part it's the former. Not the latter. He wants $15K for this '71 150 with 6200TT. And my mechanic says the first annual will run $4K - $5K. That's how I got him down from the $18-$19K range he was in. If the former, I would keep looking. If the latter, they are likely to Trouble is, if you try to deduct the price of a major overhaul, chances are the seller will balk. And, someone with the cash who does not know enough or care enough about the engine times will buy it up from under you. Deducting the price of a major puts the airplane at $2,000!! Good Luck, Mike Paul Folbrecht wrote: The 150 I had pre-buy'ed today has an O-200 with 940 SMOA but this overhaul happened 24 years ago. Mechanic has pointed out that Continental also specifies a time limit of 12 years on overhaul and thus this engine is technically runout. Do I have much cause for concern?? I know engines are quite regularly run well beyond that time interval. After all, to make that 1800 hours in 12 years you have to fly 150 hours/year. Compression is good (all in the 70s) but there is no oil analysis available. Engine sounds just fine and also has good oil pressure. I basically need to make a decision on this quickly and am stuck on this issue. I am leaning heavily towards buying it. My mechanic has said it is pretty unlikely that this time factor will result in serious problems now, but that there's really just no way to tell without an oil analysis or by watching oil consumption. __________________________________________________ __________________________ ___ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
You're absolutely right, of course. I decided against it. There's no
reason to chance this when I know there are enough 150s/152 out there with much fresher engines (in years, not operating time). I'll wait. One other thing I didn't mention: the paint stinks. It was applied poorly, with apparantly no surface prep. It is chipping off in several places. BTIZ wrote: Paul... looks like your going to get the best price at $15K... as stated before.. you could be lucky with the engine.. or not.. set up a deposit.. offer a free oil change and go get it checked if it comes back clean... that's good for today.. as an owner.. you will always need to be prepared for a complete engine overhaul BT "Paul Folbrecht" wrote in message k.net... I'm sure you will get responses saying not to worry. Those will be from others who have similar numbers and have not (yet) had a problem. Yes. Engines can be run well past TBO IF they are "overflown". For example, an engine run for 100 hours per MONTH (a.k.a. "trainer") can get 3000+ hours before going downhill. The one in question got 40 hours a YEAR. I suspect the reason some consider a plane like this is because it is close by, or because they don't have the cash to get one with better numbers. In part it's the former. Not the latter. He wants $15K for this '71 150 with 6200TT. And my mechanic says the first annual will run $4K - $5K. That's how I got him down from the $18-$19K range he was in. If the former, I would keep looking. If the latter, they are likely to Trouble is, if you try to deduct the price of a major overhaul, chances are the seller will balk. And, someone with the cash who does not know enough or care enough about the engine times will buy it up from under you. Deducting the price of a major puts the airplane at $2,000!! Good Luck, Mike Paul Folbrecht wrote: The 150 I had pre-buy'ed today has an O-200 with 940 SMOA but this overhaul happened 24 years ago. Mechanic has pointed out that Continental also specifies a time limit of 12 years on overhaul and thus this engine is technically runout. Do I have much cause for concern?? I know engines are quite regularly run well beyond that time interval. After all, to make that 1800 hours in 12 years you have to fly 150 hours/year. Compression is good (all in the 70s) but there is no oil analysis available. Engine sounds just fine and also has good oil pressure. I basically need to make a decision on this quickly and am stuck on this issue. I am leaning heavily towards buying it. My mechanic has said it is pretty unlikely that this time factor will result in serious problems now, but that there's really just no way to tell without an oil analysis or by watching oil consumption. __________________________________________________ __________________________ ___ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
I got $13,000 set aside for a OH if needed I started with a $16,000
airplane that I figure if I get 250 hours out of it paid for it self on rental fees, I know I will get a lot more than 250 hours out of my bird oil came back clean but as BTIZ says you need to be ready for an OH at any time! It is a machine and machines will break and ware out at anytime. "BTIZ" wrote in message news:AD_6c.19944$Nj.18283@fed1read01... Paul... looks like your going to get the best price at $15K... as stated before.. you could be lucky with the engine.. or not.. set up a deposit.. offer a free oil change and go get it checked if it comes back clean... that's good for today.. as an owner.. you will always need to be prepared for a complete engine overhaul BT "Paul Folbrecht" wrote in message k.net... I'm sure you will get responses saying not to worry. Those will be from others who have similar numbers and have not (yet) had a problem. Yes. Engines can be run well past TBO IF they are "overflown". For example, an engine run for 100 hours per MONTH (a.k.a. "trainer") can get 3000+ hours before going downhill. The one in question got 40 hours a YEAR. I suspect the reason some consider a plane like this is because it is close by, or because they don't have the cash to get one with better numbers. In part it's the former. Not the latter. He wants $15K for this '71 150 with 6200TT. And my mechanic says the first annual will run $4K - $5K. That's how I got him down from the $18-$19K range he was in. If the former, I would keep looking. If the latter, they are likely to Trouble is, if you try to deduct the price of a major overhaul, chances are the seller will balk. And, someone with the cash who does not know enough or care enough about the engine times will buy it up from under you. Deducting the price of a major puts the airplane at $2,000!! Good Luck, Mike Paul Folbrecht wrote: The 150 I had pre-buy'ed today has an O-200 with 940 SMOA but this overhaul happened 24 years ago. Mechanic has pointed out that Continental also specifies a time limit of 12 years on overhaul and thus this engine is technically runout. Do I have much cause for concern?? I know engines are quite regularly run well beyond that time interval. After all, to make that 1800 hours in 12 years you have to fly 150 hours/year. Compression is good (all in the 70s) but there is no oil analysis available. Engine sounds just fine and also has good oil pressure. I basically need to make a decision on this quickly and am stuck on this issue. I am leaning heavily towards buying it. My mechanic has said it is pretty unlikely that this time factor will result in serious problems now, but that there's really just no way to tell without an oil analysis or by watching oil consumption. __________________________________________________ __________________________ ___ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
Where has the plane spent its life? There is a huge difference between
sitting outside in a humid salty coastal climate and being hangered in the Southwest. I suspect that you are looking for assurance and you aren't going to find any. Until the engine is taken apart, knowing what is in there is somewhat of a guess. Mike MU-2 "Paul Folbrecht" wrote in message k.net... The 150 I had pre-buy'ed today has an O-200 with 940 SMOA but this overhaul happened 24 years ago. Mechanic has pointed out that Continental also specifies a time limit of 12 years on overhaul and thus this engine is technically runout. Do I have much cause for concern?? I know engines are quite regularly run well beyond that time interval. After all, to make that 1800 hours in 12 years you have to fly 150 hours/year. Compression is good (all in the 70s) but there is no oil analysis available. Engine sounds just fine and also has good oil pressure. I basically need to make a decision on this quickly and am stuck on this issue. I am leaning heavily towards buying it. My mechanic has said it is pretty unlikely that this time factor will result in serious problems now, but that there's really just no way to tell without an oil analysis or by watching oil consumption. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Records Show Bush Guard Commitment Unmet | WalterM140 | Military Aviation | 53 | September 13th 04 05:49 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
