In article , G.R. Patterson III
wrote: Jim Weir wrote: First person to post here that they looked at the files, they understand (more or less) the task at hand, and are willing to take a crack at the first one has it. Ok, Jim. I looked at the files and put together the pages for August from the files you provided. I did have to change the "oopsie" page from a pdf download to an html file, since I can't create pdfs. I will send you a zip file shortly. George, forward whatever you want converted to PDF to me. I have a full version of Acrobat. |
![]() Jim Weir wrote: I also posted all the JULY 2002 files in /kptest as well. I've got them down. Looks like August instead of July. I've looked at the June files you provided and will take a stab at August tomorrow. Thanks, George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
George Patterson took the task on and has done an absolutely splendid job
translating the first article. To have a looksee a George's handiwork, www.rstengineering.com/kitplanes and go to the bottom article (July '02). George, the gang owes you one, and so do I. The August '02 raw data is posted in the usual place. Jim - -Again I ask...is anybody fool enough to take my Kitplanes column raw data and -put it into downloadable format for the rest of the gang? Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote:
To have a looksee a George's handiwork, www.rstengineering.com/kitplanes and go to the bottom article (July '02). Not Found The requested URL /kitplanes/KP0207/KPtext.pdf was not found on this server. Apache/1.3.20 Server at www.rst-engr.com Port 80 Dave |
Works in Texas...
"Dave Butler" wrote in message ... Jim Weir wrote: To have a looksee a George's handiwork, www.rstengineering.com/kitplanes and go to the bottom article (July '02). Not Found The requested URL /kitplanes/KP0207/KPtext.pdf was not found on this server. Apache/1.3.20 Server at www.rst-engr.com Port 80 Dave |
Dave Butler wrote:
Jim Weir wrote: To have a looksee a George's handiwork, www.rstengineering.com/kitplanes and go to the bottom article (July '02). Not Found The requested URL /kitplanes/KP0207/KPtext.pdf was not found on this server. Apache/1.3.20 Server at www.rst-engr.com Port 80 Dave There's two mismatches between the KP0207.htm file and the other files: the parts list file and full test PDF are Kpparts.pdf and Kptext.pdf on the webserver, but are KPparts.pdf and KPText.pdf in the URLs in the KP0207.htm file (note the case difference in the "P"s). So the real URLs to the full text and parts list a http://www.rst-engr.com/kitplanes/KP0207/Kpparts.pdf http://www.rst-engr.com/kitplanes/KP0207/Kptext.pdf I imagine that the above to references will break here shortly when Jim fixes the KP0207.htm file or renames the PDFs. Russell Kent |
George...
In terms that any competent history major can understand, can you tell me how you want me to fix this type mismatch? Jim -There's two mismatches between the KP0207.htm file and the other files: the parts -list file and full test PDF are Kpparts.pdf and Kptext.pdf on the webserver, but are -KPparts.pdf and KPText.pdf in the URLs in the KP0207.htm file (note the case -difference in the "P"s). So the real URLs to the full text and parts list a - -http://www.rst-engr.com/kitplanes/KP0207/Kpparts.pdf -http://www.rst-engr.com/kitplanes/KP0207/Kptext.pdf - -I imagine that the above to references will break here shortly when Jim fixes the -KP0207.htm file or renames the PDFs. - -Russell Kent Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
![]() Jim Weir wrote: In terms that any competent history major can understand, can you tell me how you want me to fix this type mismatch? Well, the fastest way to fix it is to rename the two files to match the URLs. Alternately, I can change the URLs in the html file and resend that. If you go the first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf" to "KPText.pdf". The difference in names also exists on my computer; the reason I didn't catch it is that the link still works for me. It didn't show up in testing. I'll double-check for that sort of thing with August. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
Renamed both the files with the KP prefix. Try to break it again, if you would
please. Jim - -There's two mismatches between the KP0207.htm file and the other files: the parts -list file and full test PDF are Kpparts.pdf and Kptext.pdf Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote:
Renamed both the files with the KP prefix. Try to break it again, if you would please. Seems fine now. Dave |
Does anyone have Kitplanes Mag's from 1986? | Nunya | Home Built | 10 | June 21st 11 07:22 AM |
unfair cartoon in October 2004 issue of KITPLANES | Bob Kaplow | Home Built | 31 | August 29th 04 02:00 PM |
Columns by a Canadian centre controller | David Megginson | Instrument Flight Rules | 1 | August 9th 04 10:05 PM |
Kitplanes August Issue | Badwater Bill | Home Built | 28 | July 6th 04 08:26 PM |
Kitplanes Columns | Jim Weir | Home Built | 30 | April 14th 04 08:23 PM |
