#11
How does that work? Is the tail like the Mooney, where the trim
moves the whole horizontal stab? I'm not familiar with the tail of the Mooney. The Seneca does have a stabilator and an anti-servo tab. There is no problem with stabilator authority, it's just the amount of physical strength required is high at low airspeeds. |
Greg Esres wrote
I'm not familiar with the tail of the Mooney. The Seneca does have a stabilator and an anti-servo tab. There is no problem with stabilator authority, it's just the amount of physical strength required is high at low airspeeds. The Seneca stabilator with anti-servo tab design is pretty much lifted from the Twin Comanche (no surprise), which is also very heavy in pitch as it is slowed from blue line to landing speed. Without massive retrimming, a good landing is impossible. I never did get the hang of landing mine properly until I got the electric trim working. Then I would trim all through short final and flare, and it worked out OK. Fix the electric trim. The usual problem with inoperative electric trim in that system is that nobody has cleaned or lubed the trim pulleys in years. Michael |
Michael wrote: The Seneca stabilator with anti-servo tab design is pretty much lifted from the Twin Comanche (no surprise), which is also very heavy in pitch as it is slowed from blue line to landing speed. Without massive retrimming, a good landing is impossible. I have a single Comanche. The trim is super sensitive at cruise airspeeds. There's a very definite reaction to a slight trim change. You could fly across the country on less than half (maybe a quarter) of the throw of the crank. In the slow flight regime you need massive trim travel. Between cruise and landing there are 5 or 6 full turns of trim (not sure exactly since I use the electric trim). You need to take 2 or 3 of those off before takeoff or it will be a real adventure. hang of landing mine properly until I got the electric trim working. Then I would trim all through short final and flare, and it worked out OK. I stop trimming when I hit 80mph, and I'm not sure there's much left, but you're probably crossing the fence faster than that in a twin. Even so it's a lot of work on a go-around while you wait for the trim to come out. Fix the electric trim. The usual problem with inoperative electric trim in that system is that nobody has cleaned or lubed the trim pulleys in years. In my case the trim motor (behind the baggage compartment near the top of the plane) had 3 wires going to it, and the shortest one was the only strain relief, and it eventually broke off. Be careful not to get any lube on the trim cable or the pully surfaces, though. If you do you'll never get it off and the motor won't have any traction. -- Ben Jackson http://www.ben.com/ |
| Thread Tools | |
| Display Modes | |
| VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 06:22 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
| WTB: Nose Gear Assembly for Early Model Bonanza | Eric Ulmer | Aviation Marketplace | 4 | November 16th 03 11:50 PM |
