Wet Signature on W&B?
Old April 14th 04, 03:40 PM
Ray Andraka
When you weigh a plane, what is required for paper work? I imagine an equipment
list as installed with the nominal weights and CG's of installed equipment such
as radios similar to the original equipment list is needed.
Otis Winslow wrote:
I can't recall seeing anything with the requirment to have the actual signed
copy
in the plane. I've always kept that with the log books. I keep a copy of it
in the
plane.
As for trying to come up with an accurate one, that's often an effort in
futility. Having
been faced with multiple revisions, seemingly carefully updated several
times, I've
opted to just weigh the plane. And it's always been off significantly from
the brought
foreward updates. Plus it's probably cheaper than spending several hours
trying
to figure it out.
"Jim Weir" wrote in message
Got asked a question that I can't find the answer to.
Say I take a feller's logbooks home during the annual and after a few
hours of
grunt and scream I come up with what I think is the current equipment list
and a
defensible weight and balance. I sign off the w&b in the logbook and give
feller the printout equipment list with the same weight and balance
figures as
are in the logbook.
I print this out with my printed name and certificate number at the
bottom, but
don't sign the printout. Or he asks a few months later for a copy of the
w&b by
email. I sure as hell have a hard time poking ink down the phone lines.
So, sez, I, where in the regs is it stated that the w&b that you carry on
board
the airplane needs a signature? I can't find it. Please, no answers
telling me
how to cut and paste a signature into a spreadsheet. That is child's
play, and
besides, how the hell do you know that somebody didn't cut and paste phony
data
over my signature?
So, chapter and verse REQUIRING a signature on the w&b in the aircraft?
http://www.rst-engr.com
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old April 14th 04, 03:43 PM
G.R. Patterson III
Nope. A logbook entry stating that it was weighed and a new weight and balance sheet.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 14th 04, 06:53 PM
Otis Winslow
The maintenance manual will have the procedure to use for weighing
the plane and calculating the W&B. That's what I've used.
"Ray Andraka" wrote in message
equipment
such
signed
copy
it
in the
plane.
futility. Having
times, I've
from
the brought
trying
to figure it out.
hours of
list
and a
give
figures as
are in the logbook.
bottom, but
w&b by
lines.
on
board
telling me
play, and
phony
data
over my signature?
aircraft?
--Ray Andraka, P.E.
email
Old April 15th 04, 02:22 AM
Newps
Depends on the plane. For my 182 we just weighed it last week during
the annual. I completely drained the tanks, then ran the engine until
it died. Then we weighed it. Then we also figured the CG as per the
Cessna drawing. My plane is 50 pounds heavier than the last revision
and the CG is 1/2 inch farther forward. I have an equipment list that I
made on the computer.
Old April 14th 04, 03:59 PM
Tony Cox
"Otis Winslow" wrote in message
futility. Having
times, I've
the brought
trying
to figure it out.
Make sure that the weigh station uses the correct procedure. I spent
several hours trying to reconcile a 60lb difference between equipment
added since new & an 'official' weigh in 1995. (I've a 1966 182).
Turns out that the official "Cessna" way is to drain all the fuel. The
weigh station weighed it when full of fuel & subtracted the difference
mathematically. The fuel tanks contain more than advertised, as
I later verified when complying with a fuel tank SB which required
me to drain all the fuel. So I'm being cheated out of 60lbs in legal
payload by my current W&B sheet. One day I'll fix it.
The 'weigh' was before I owned the plane.
Old April 14th 04, 05:11 PM
mikem
The proceedure for backing the weight of fluids out
of the W&B calculation varies by model year (or
serial number range). The proceedure is specified
(By Cessna) in the 182's Type Data Sheet, which
your IA should be looking at during an annual inspection.
I have a copy of the TDS in my logs with all of the relevant
parts high-lighted for my L model.
MikeM
futility. Having
times, I've
the brought
trying
to figure it out.
Old April 14th 04, 05:25 PM
Tony Cox
"mikem" wrote in message
I didn't realize it was model year specific, but from my
Type Data Sheet the procedure is to drain all the
fuel, which of course wasn't done. Hence the 60lbs discrepancy.
Old April 15th 04, 04:29 AM
MikeM
If the AP that weighed it is still around, then print out
the TCDS specific to your model year, recompute the W&B to
your favor, take it to the AP. He/she should be willing to
sign the corrected WB at no charge. If not, ask if you should
take it to the FSDO to have it recomputed...
MikeM
How long to keep VOR check records? Ross Oliver Instrument Flight Rules 27 April 10th 04 06:57 PM
F-22 Lies robert arndt Military Aviation 59 January 18th 04 05:43 AM
D'Amato's Role Investigated in La Guardia Airport Deal Roy Smith General Aviation 0 December 25th 03 05:47 AM
Flyong from Toronto (Ontario) to Pitsburg Intl Anthony Acri Instrument Flight Rules 3 July 26th 03 05:28 PM
