Aeronautical Engineering Help needed
Old December 25th 03, 10:00 PM
Marc A. Lefebvre US-775
Nat Puffer wouldnt be able to help as it is NOT with HIS design, as I
said a canard design "LIKE" the COZY. I suppose if I had said "like"
a Long-EZ you would have recomended Burt as well? hehehehe... Try
again...
Looking for modelling software, not people... Looking to do some
analysis of some designs. Something along the lines of a virtual wind
tunnel testing, stress and load testing, etc... There has to be
someone with a clue in this group somewhere. (Hoping, atleast)
Marc
"Larry Smith" wrote in message ...
"Marc A. Lefebvre US-775" wrote in message
m...
Hello,
I am looking into modifying one of the canard designs like the COZY
MkIV and wanted to know what the best way to ensure that what changes
Call Nat Puffer. He'll be tickled to help you.
Old December 27th 03, 02:49 AM
Nicholas Cafarelli
Wingco used the X-plane simulator to help with their new design.
http://www.wingco.com
http://www.x-plane.com
Profili and xfoil are serious tools for airfoil analysis. Profili is
an inexpensive front end for xfoil. xfoil recently became freeware.
http://www.profili2.com/eng/default.htm
http://groups.yahoo.com/group/xfoil/
There are many other firms offering software packages for aircraft
design. Spend some time learning about structuring Google queries and
you will find them. Seriously.
http://www.google.com/help/
Aircraft design is dead serious. The more you know the more dangerous
you become - you can die or cause others to die.
I do not mean to discourage you. However, ... beware.
Only airtime proves airframes.
Fly right.
nc
Old December 25th 03, 05:50 PM
Marvin Barnard
Hi Marc,
I frequently get questions from folks who want to make changes
to my design. It's human nature to want to build "a better mouse trap".
There are several available chart type plots of general aerodynamic
formulas boiled down into graphic comparisons of areas, forces, speeds,
weights,.........etc. (I.E. McCoy's, or Beaujon's aerodynamic
tablature)
You won't get any solid usable advice (none you want to hear) from
a design holder or probably many builders either.
Do the aerodynamic calculations and intentionally over build
strength-wise. You're almost on your own. .....Guess that's why we're
"Experimental" aviators.
......Good luck!
Old December 29th 03, 05:01 PM
David Lednicer
As an aeronautical engineer, I'll give you some free advice regarding
modifying a canard configured aircraft: don't
Old December 31st 03, 04:27 PM
Dan Apel
As another aeronautical engineer I strongly agree (and second) this opinion.
BTW if you want long range a canard is not for you.
"David Lednicer" wrote in message
Old January 1st 04, 12:42 AM
David O
Your assertion rings false in both theory and practice. There is
nothing inherently range-limiting about a canard design. Of the
popular canard homebuilt designs, most rank quite well in cruise
range. A stock Long EZ, for example, will fly 1000 miles full
throttle at altitude (75% power) and land with VFR reserves in the
tanks. The Class C-1a and C-1b world records for range are held by
canard aircraft.
David O -- http://www.AirplaneZone.com
Web site info needed dave Home Built 1 December 3rd 03 04:12 AM
parachute needed VO Aerobatics 1 November 25th 03 12:35 AM
Cable parts needed in Dallas dave Home Built 4 October 23rd 03 04:12 AM
0-235 lyc cylinders needed (3) Captain Dave Home Built 0 October 8th 03 08:00 PM
PSRU - Universal Engineering Merle Wagner Home Built 0 July 7th 03 12:38 AM
