#11
![]() The cutout relay opens the path between the armature and the battery. This relay closes when the generator RPM is high enough to generate a voltage that is equal or exceeds the battery voltage. When the cutout relay closes the heavy wire coil on the relay adds more flux to keep the relay closed. When the generator RPM decreases so that the generator voltage is less than the battery voltage, the battery tries to "motor" the generator and the current through the heavy wire winding reverses and opposes the flux from the fine wire winding causing the relay to open which disconnects the generator from the battery. This sounds like the most reasonable thing happening. I'm thinking that a fine adjustment on the cutout relay tension might be all that is needed. Jim |
Landing light | Hankal | Aviation Marketplace | 0 | July 14th 04 01:23 AM |
Would a 3 million Candlepower spotlight make a good landing light? | Legrande Harris | Home Built | 6 | June 15th 04 06:32 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
74 Archer Nav light switch | Mike Noel | Owning | 8 | January 14th 04 03:56 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
