Anyone keeping a fabric plane in the open?
Old May 24th 04, 02:51 AM
Dan Thomas
Fabric suffers from UV more than anything. I've seen some
factory-covered airplanes that have almost no UV blocker, and you can
see daylight through the fabric while crawling around in the fuselage
or snooping through acces holes in the wings. It shoud be completely
dark in there; no UV or visible light.
Stits finishes are PVC (polyvinyl chloride), except for their
urethane finishes which are tough and shiny and a whole lot harder to
repair. Both weather well. Other urethane finishes are available but
many don't have the flexibility for fabric; they're intended for solid
surfaces and will eventually start cracking as the fabric flexes.
BTDT. Tires suffer from UV and ozone in the air.
Dark finishes result in more solar heating of the fabric, which
embrittles and weakens it over time. It can, in extreme cases, cause
further shrinkage of the fabric and crushing of airframe structure.
Water from rain, snow or condensation can get into the structure
and cause corrosion. In our climate, the winter snow can be very fine
and dry like dust, and gets into everything during a blizzard. Of
course, such fine stuff has little moisture in it and it can evaporate
(sublimate) when the sun comes out again. And then there's hail and
wind. I've seen some perfectly good airplanes damaged by wind, even
though they're still tied down. Control surfaces and stops beat up,
cables stretched, paint and plexiglass eroded by flying sand. Covers
are great but if the dust gets under them, you now have sandpaper
working on it. Dust gets inside the airplane, too. Adds weight and
clogs things up.
Dogs pee on props left poistioned vertically; saw one that had
holes eaten through it while it had sat through generations of canine
visitors. (Another reason to fly taildraggers!)
Biggest hassle with outdoor storage is probably the birds and
mice and their nests and poop and the resulting corrosion. They can
find ways into almost any airplane. Mothballs keep them out. Might
keep some of your passengers out, too. Everything's a tradeoff.
Dan
Old May 24th 04, 03:20 AM
bubba
The fabric will last forever if the sun doesn't get to it!
If the topcoat doesn't comprimized there should be no problems.
After time the dope looses its flexability and cracks, which lets the
light get to the fabric.
If the dope is rejuvenated, it puts the flexability back into the dope
and your good to go. It's like putting a new coat of dope on the airplane.
It's all a game on keeping the UV away from the fabric which means that
the topcoat needs to be attended to to keep that from happening.
Fabric aircraft are absolutly great, they just have different care
instructions than spam can aircraft.
Cheers
Dave
clogs things up.
Dan
Old May 24th 04, 03:06 PM
jls
"Dan Thomas" wrote in message
om...
Well, I think you're correct with regard to Stits or Polyfiber. But
doesn't one or two of the polyester aircraft covering systems claim to
filter out UV rays, allowing the visible infrared rays to go on through?
clogs things up.
Dan
Excellent information. Thanks.
Old May 25th 04, 03:37 AM
dave
Thanks George. I don't think I'll have that done when a get that little
patch next month but the annual is just around the corner. We'll see.
Dave
68 7ECA
G.R. Patterson III wrote:
dave wrote:
I was going to try 1000 grit paper but a
fabric guy told me that they could try a rejuvinator on it.
Rejuvenator is a solvent that softens butyrate dope.
George Patterson
I childproofed my house, but they *still* get in.
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 04 06:28 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 9th 04 03:47 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 04 06:27 AM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 12:17 AM
A Good Story Badwater Bill Home Built 15 September 3rd 03 03:00 PM
