slightly high aluminum in an IO-360
Old May 27th 04, 12:02 AM
Robert M. Gary
"G.R. Patterson III" wrote in message ...
"Robert M. Gary" wrote:
I've checked the filter beofre and not found anything. However, I've
never checked the screen. I'm not sure if my IA is doing that during
annual or not.
The screen should be checked every 50 tach hours. If the shop is changing the oil as
part of the annual, they almost certainly are checking the screen. If they aren't I
would wonder what else they're skipping.
I'm sure the shop is doing it but I do most of the oil changes myself
(except the one at annual). I'm not checking the screen. I'll have to
schedule some time with the A&P to have him show me how to do it. The
Lycoming guy said they've seen cases where a filter has come out clean
because there were so many chunks of big metal plugging up the screen.
-Robert
Old May 27th 04, 04:36 AM
G.R. Patterson III
I check mine every other oil change, whether I've run up 50 hours or not. My engine
is an O-320. On that, the screen looks like a horizontal drain plug on the sump.
Safety-wired, of course.
George Patterson
None of us is as dumb as all of us.
Old May 27th 04, 04:42 PM
Orval Fairbairn
engine
sump.
George Patterson
I check mine every oil change (25 hr) AND, I have a niobium magnet in
each drain plug, to collect all ferrous metals.
IMHO, the magnet asved my plane (possibly my life) a couple of years
ago, when I found some flattened pieces of steel, anout .05" across.
They were coming from the big roller bearing that serves as a thrust
bearing -- its cage had broken and it was making some noises which I
could hear at idle.
The steel drain plugs are the perfect place to put one or two of these
magnets, as they are self-attaching.
Old May 27th 04, 05:24 PM
G.R. Patterson III
I replaced my drain plug with a quick-drain. That would certainly complicate using
the magnets on my aircraft.
George Patterson
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
