Winter glider storage?
Old November 12th 11, 09:45 PM posted to rec.aviation.soaring
Default Winter glider storage?
I've wintered my glider outside in the PNW, but it is NOT preferred. Of course, it is best to put your trailer under a carport or, if possible, in a garage (which is where I store mine now and would never go back outside).
Gently heating the inside of the trailer is a essential. Be careful with all heat sources. Electric heaters should have auto off in case they tip over for some reason. They should have some type of insulation from direct contact with the trailer (bricks work nice). Light bulbs have been known to cause fires, so I would avoid them. My preference is a chick incubator available at your local rural hardware store. It is low voltage and usually insulated.
Air flow is essential. Don't plug up the vent sources.
Dri-z-aire needs regular attendance. Follow the instructions provided.
Good luck.
Preparing glider for storage Ben C Soaring 6 September 27th 11 02:13 AM
Where to earn Glider Rating this fall / winter [email protected] General Aviation 0 September 5th 05 01:37 AM
Finish Your Glider Rating This Winter Burt Compton Soaring 0 December 4th 04 02:13 PM
risky storage? R.Hubbell General Aviation 3 February 11th 04 07:17 AM
103 Storage BTIZ Soaring 3 November 18th 03 12:47 AM
