Pre-buy Inspection
Old August 29th 04, 04:10 PM
Michael Horowitz
Jon Kraus wrote:
Jon Kraus
PP-ASEL-IA
Student aircraft purchaser
Although apparently not usually part of a pre-buy, may I suggest you
ask the inspector the check the run-out of each engine?
I had an 'incident' with my BC-12D which caused the A&P to check the
engine run-out and it was out of limits, which required that we open
the engine and look around. Turned out the flange/hub was not exactly
perpendicular to the shaft, and since I'm running a wooden prop and it
was in fine shape, the thought was something happened long ago and
went unnoticed until now. - Mike
Old August 29th 04, 09:35 PM
Ben Jackson
Jon Kraus wrote:
One of the cylinders has a compression of 62 while the others are in the
70's. This concerns me even though it is within tolerances.
What should concern you is if the leak is past the valves rather than by
the rings.
Ben Jackson
http://www.ben.com/
Old August 30th 04, 02:41 AM
Eclipsme
"Ben Jackson" wrote in message
news:B6rYc.336985$%_6.247476@attbi_s01...
the rings.
As well as the trend over the last few inspections, I would think...
Old August 30th 04, 12:50 AM
Robert M. Gary
Jon Kraus wrote in message . ..
My new partner and I are looking at a 1975 Mooney M20C. It is a nicely
upgraded IFR plane with a 400 hour O-360 engine. It is a rather high
time airplane (7000) hours and the price reflects this fact. It is being
sold by the owner of the FBO we fly out of for one of his friends. They
just finished up an annual inspection on it.
A Mooney is a pretty hard plane to get a good pre-buy on. You really
need to go to a Mooney specialty place. There are great hidden places
underneath where fatal rust can hide from all but the good specialist.
You also need the tank sealant inspected. Some leaking is normal but
you are concerned with the condition of the sealant. A reseal will
cost around $9000. You are looking for pealing and flaking of the
sealant. Pin holes are normal. A good AD search should be done on the
gear actuator. The AD is VERY complicated in that some actuators are
covered and others not. Sometimes the inside is the same. You at least
want to be sure the actuators are lubed really good. Very few A&Ps
know how to do that. You need to "exercise" the gear in a special way
to allow the grease to work in. The donuts should also be checked.
They are your only suspension. When they wear out you will start
leaking fuel from the tanks pretty quick because it causes the tank to
flex on landing when they are worn out. You also need to have the
preload checked on all the gear. There is a special tool to do that. 1
in 2 A&Ps don't know how to use it (I went to a Mooney maintenance
semenar where several A&Ps who had been working on Mooneys had to be
shown how to use it).
Don't let this run you off. There really aren't many planes out there
as great as a Mooney. I should know, I have one myself.
-Robert
Old August 30th 04, 04:54 AM
Lynne Miller
Truthfully, a good pre-buy is actually an annual inspection. I would
worry about a $500 pre-buy. Unless you truly tear into the aircraft,
you don't know what you're getting into. If it's at all close by,
perhaps you could work out a deal to somehow pro-rate the annual
inspection, and just get it done. That way, you will at least have the
peace of mind to know exactly the shape the aircraft is in.
As an aside, I am quite drunk right now. :-) It's fun to hang out at
home, drink beers, and just relax.
Lynne
My IFR instructor has owned Mooneys in the past and even had the M20C
for years. He suggested that we fly the plane to Byerly Aviation in
Peoria IL (a little over an hour flight from Indianapolis) and have them
do the pre-buy. He said it would probably cost in the $500.00 range. My
partner and I think it is a good idea too. We are both buying our first
plane and think the money would be well spent.
70's. This concerns me even though it is within tolerances. Of course we
would hate to buy something that needed immediate major engine work. The
plane has not flown much for the past 2 years so I am wondering if after
flying the thing a while if the compression might come back some
(probably wishful thinking I know).
I am interested in opinions or experiences in first plane purchases.
Experience with Byerly Aviation. Or comments on the engine situation I
described. Thanks!!
Jon Kraus
PP-ASEL-IA
Old August 30th 04, 01:06 PM
Jon Kraus
When you sober up and read the posts you would discover that the plane
has just come out of an annual. JK
Lynne
described. Thanks!!
Jon Kraus
PP-ASEL-IA
Old August 30th 04, 03:53 PM
Peter Duniho
"Jon Kraus" wrote in message
IMHO, an annual inspection done (paid for) by the seller is worthless with
respect to pre-buy inspection.
I base this on personal experience, having bought a plane that had just had
an annual inspection done, and yet which still had significant problems,
including safety issues.
When buying an airplane, you *cannot* delegate ANY inspection of the
aircraft to the seller or anyone hired by the seller. The only way to know
for sure the condition of the airplane is to inspect it yourself or have
someone working for you inspect it. If you decide that an inspection the
depth of an annual inspection is warranted, then so be it...even if the
airplane has just had an annual inspection by someone else, you'll have to
pay someone to do it all over again.
The fact that the plane in question here has just come out of its annual
inspection is meaningless to the buyer.
Pete
Old August 30th 04, 04:16 PM
Jon Kraus
I agree with you 100%. Matter of fact the seller just informed my FBO
that he will not allow the plane to inspected by Byerly Aviation who is
a well respected Mooney shop. I think we are going to pass on this one.
Jon Kraus
PP-ASEL-IA
Student airplane purchaser
Pete
Old August 30th 04, 09:58 PM
Bob Noel
In article , Jon Kraus
something to consider: The seller might not like the shop because
of a bad experience. I know one A&P that I won't let touch my
airplane ever again (but he's not in the IL area).
Bob Noel
Seen on Kerry's campaign airplane: "the real deal"
oh yeah baby.
Old August 30th 04, 05:26 PM
G.R. Patterson III
You still want to have an inspection performed to the standards of an annual
inspection by a mechanic you trust. Sellers have been known to obtain a
"pencil-whipped" annual when they know they intend to sell the plane in the near
future.
George Patterson
If you want to know God's opinion of money, just look at the people
he gives it to.
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 11:52 AM
Service Manual - 50 hour inspection O. Sami Saydjari Owning 1 April 8th 04 03:17 PM
51st Fighter Wing betters rating to ‘excellent’ with inspection Otis Willie Military Aviation 0 February 20th 04 11:29 PM
100 Hour Inspection Question FryGuy General Aviation 59 November 19th 03 04:01 AM
