#11
On a similar note, if a cylinder compression was low, would you rebuild
it, or buy a new one? It depends. Depending on the problem, and age of the cylinder, I'd probably still buy new. When you look at a new Millennium cylinder, and see where they have beefed up the areas most likely to crack, it's an easy choice. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Jay Honeck wrote: If you buy a rebuilt cylinder you do not know if it has 500 hours or 5000 hours. You also can not always tell if it has already cracked and been welded. Why in the world would anyone buy a rebuilt cylinder nowadays? The price differential between new and used is so small Where are you shopping? A new cylinder is about $1K. Around here overhauled cylinders, chromed are $350. -- and the risks are just too great. Heck, I wouldn't put a rebuilt cylinder on my CAR (not that any such thing is ever necessary on modern automobiles), let alone an airplane. I have 6 chromed first run cylinders on my 182, can't see why you wouldn't go that way. |
"Jay Honeck" wrote in message news:8Q38d.171959$D%.3931@attbi_s51...
If you buy a rebuilt cylinder you do not know if it has 500 hours or 5000 hours. You also can not always tell if it has already cracked and been welded. Why in the world would anyone buy a rebuilt cylinder nowadays? There does seem to be a general opinion that new Continental cylinders are not a good buy. Both L&C seem to have lost their best metallurgical engineers. |
But don't buy them from J & J Air parts in Texas.
Trip In article jic8d.168563$MQ5.108036@attbi_s52, says... On a similar note, if a cylinder compression was low, would you rebuild it, or buy a new one? It depends. Depending on the problem, and age of the cylinder, I'd probably still buy new. When you look at a new Millennium cylinder, and see where they have beefed up the areas most likely to crack, it's an easy choice. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote It depends. Depending on the problem, and age of the cylinder, I'd probably still buy new. When you look at a new Millennium cylinder, and see where they have beefed up the areas most likely to crack, it's an easy choice. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" The reason I was asking is that the plane I'm buying needed a cylinder rebuilt, and the owner elected to have it rebuilt rather than buy a new one. I'm sure it will be OK...but for how long? All I can say is that the owner has been extremely agreeable. We had that agreement that he may or may not fix anything above $500. So far, the annual has been about $4K, and he has been more than happy to fix everything (including the cylinder rebuild). |
So far, the annual has been about $4K, and he has been more than happy to fix everything (including the cylinder rebuild). Good to hear you found a good seller. More often we hear about the shysters... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Adam,
On a similar note, if a cylinder compression was low, would you rebuild it, or buy a new one? If it's low e.g. because an exhaust valve is leaking rebuilding would make sense, would'nt it? Regards Kai |
![]() Adam, On a similar note, if a cylinder compression was low, would you rebuild it, or buy a new one? If you have a bad valve there's no rebuilding to do. You put in a new valve and go flying. |
With everyone criticizing Lycoming and Continental, I will point out a
couple of items. I have Lycoming 1996 0-360 in my Husky. Since NEW, it has 2200 tach time (about 2600 Hobbs). No oil usage, no metal in the filter, oil analysis is good and makes above 70 on the compression. Goes as fast and climbs as well as when new. Engine has never had any engine components serviced. (accessories like alternator, yes). I know of a certain government aircraft (two actually), Cessna 185's that have AWAYS made TBO. They automatically replace the engine at TBO with Continental factory rebuilt. They have gone through 6 engines over the years, and EVERY engine has made TBO without cylinder replacments. The 185 engines are notorious for cracked cylinders. Then I hear of rebuilt engines from whoever, cracked cylinders, rebuilt cylinders etc. But the above are factory Lycoming and factory Continental. All stock factory components. And they did just fine. |
![]() Doug wrote: With everyone criticizing Lycoming and Continental, I will point out a couple of items. I have Lycoming 1996 0-360 in my Husky. Since NEW, it has 2200 tach time (about 2600 Hobbs). No oil usage, no metal in the filter, oil analysis is good and makes above 70 on the compression. Goes as fast and climbs as well as when new. Engine has never had any engine components serviced. (accessories like alternator, yes). Lyc's last a long time. But look at the prices of new ones from the factory, they are more than two and a half times the cost of a similar Continental. This is because Lyc is recouping the cost of their crankshaft debacle of a couple years ago. The cost of a new Cessna 206 could be reduced by 80 Grand if they simply switched back to a Continental. I know of a certain government aircraft (two actually), Cessna 185's that have AWAYS made TBO. They automatically replace the engine at TBO with Continental factory rebuilt. They have gone through 6 engines over the years, and EVERY engine has made TBO without cylinder replacments. The 185 engines are notorious for cracked cylinders. Then I hear of rebuilt engines from whoever, cracked cylinders, rebuilt cylinders etc. But the above are factory Lycoming and factory Continental. All stock factory components. And they did just fine. Buddy of mine has a PA-12 with 6500 SMOH and 3500 since the last top. |
Typical speeds on a low altitude flight? | Bjørnar Bolsøy | Military Aviation | 5 | September 22nd 04 02:59 PM |
Compression loss on cylinder when rings line up Truth of fiction? | test it | Home Built | 10 | May 11th 04 08:11 PM |
#5 cylinder not firing | David R. | Owning | 13 | February 27th 04 12:41 PM |
Cylinder Wrenches for 0-320A Narrow Deck | DAVE | Home Built | 1 | December 31st 03 01:45 PM |
'Hot' cylinder after overhaul? | Tony Cox | Owning | 8 | August 10th 03 07:25 PM |
