Newps wrote:
: but speed goes up as the cube root of power.... i.e. doubling the power gives you : 2^(1/3) = 25% more speed for a given airframe. So a Cherokee 180 at 135 mph will go : to at most 170 mph if you could strap on a 360 hp engine. : That formula has always been taken as gospel but the real world truth is : if you could get a 360 hp engine under the cowl you would go a lot : faster than just 170 mph. My buddy and I both have 182's. I have the : standard 230 hp engine, he has the IO-550 300 hp engine in his. Even : though he has more drag because he has much larger tires than I do as : well as bubble windows on both front side windows he typically indicates : 30 mph faster thah I do, and he lost 5-7 mph with the 3 8.50 tires over : the 8.00x6 mains and 6.00x6 nose like I have. And while he goes : virtually straight up he cannot legally haul more. While I won't argue with your specific results, they really can't be considered the norm. Even though two planes are identical models, they cannot be directly compared from differences beyond control (mis-rigging, different weights, the things you mentioned, etc). Take a look through a multi-purpose POH (e.g. PA-28-150,180, or PA-24-180,250,400)... the numbers line up. e.g. Book: Ratio^1/3 (relative to 250) PA-24-180: 139ktas 140ktas PA-24-250: 157ktas base PA-24-400: 185ktas 184ktas Awfully close numbers. Again, I'm not saying your numbers are wrong, just that it holds remarkably well to published numbers. According to hp, he should indicate 9.3% more speed than you. I doubt you're doing 323 mph in a 182... ![]() -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Nathan Young wrote: Great description - so to summarize - in cruise, the CS prop would only benefit over a fixed pitch in cases where the fixed pitch prop is redlined before running out of throttle. Yes, but also the other way around too. Climb real high with a fixed pitch so even when you're at full throttle you can only get say 2100 rpm in your 172. In my 182 I can always get the full max continuous 2450 rpm, regardless of what the manifold pressure may be. |
Nathan Young wrote: Can you better explain this? My understanding is that a fixed pitch prop is typically a compromise in both takeoff pitch, and cruise pitch. Using the typical car driving analogy - a prop that is stuck in 3rd or 4th gear in a 5 speed transmission. So I would think a CS prop would net gains at both cruise and takeoff/climb. They usually do, for the reasons you stated. If you adjust the controls such that the engine is producing 75% power in level flight and the CS prop settles into a coarser pitch than the fixed pitch prop had, you'll see a faster cruise speed. If the fixed pitch prop was pitched to produce the best cruise speed, the CS prop won't do any better there, but will improve your ROC. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
G.R. Patterson III wrote: Nathan Young wrote: Can you better explain this? My understanding is that a fixed pitch prop is typically a compromise in both takeoff pitch, and cruise pitch. Using the typical car driving analogy - a prop that is stuck in 3rd or 4th gear in a 5 speed transmission. So I would think a CS prop would net gains at both cruise and takeoff/climb. They usually do, for the reasons you stated. If you adjust the controls such that the engine is producing 75% power in level flight and the CS prop settles into a coarser pitch than the fixed pitch prop had, you'll see a faster cruise speed. If the fixed pitch prop was pitched to produce the best cruise speed, the CS prop won't do any better there, but will improve your ROC. In the performance charts for my 182 a given percent power always produces the same speed at a given altitude. |
Newps wrote: G.R. Patterson III wrote: Nathan Young wrote: Can you better explain this? My understanding is that a fixed pitch prop is typically a compromise in both takeoff pitch, and cruise pitch. Using the typical car driving analogy - a prop that is stuck in 3rd or 4th gear in a 5 speed transmission. So I would think a CS prop would net gains at both cruise and takeoff/climb. They usually do, for the reasons you stated. If you adjust the controls such that the engine is producing 75% power in level flight and the CS prop settles into a coarser pitch than the fixed pitch prop had, you'll see a faster cruise speed. If the fixed pitch prop was pitched to produce the best cruise speed, the CS prop won't do any better there, but will improve your ROC. In the performance charts for my 182 a given percent power always produces the same speed at a given altitude. I'm sure it does, but you would not see that speed if you replaced your CS prop with a fixed pitch prop that has the compromise pitch that is commonly used on aircraft with fixed pitch props. Most aircraft with fixed pitch props have a prop that has too fine a pitch to get the best cruise speed at 75% power. Replacing that prop with a CS prop will result in higher cruise speeds. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Nathan Young wrote in message . ..
On 7 Oct 2004 13:02:37 -0700, (PaulH) wrote: At any altitude that permits you to develop 75% power with your current prop, a constant speed prop won't gain you an inch unless you want to fly at a higher power setting. Can you better explain this? My understanding is that a fixed pitch prop is typically a compromise in both takeoff pitch, and cruise pitch. Using the typical car driving analogy - a prop that is stuck in 3rd or 4th gear in a 5 speed transmission. So I would think a CS prop would net gains at both cruise and takeoff/climb. The fixed pitch prop IS a compromise, but if the prop is pitched to permit generation of 75% power, it doesn't matter what the angle of the prop is. The only thing the CS prop provides at cruise is a choice of RPM for the same power. I can cruise at 22" and 2400 RPM and get 155 mph in my Arrow or 25" and 2100 RPM. They both generate 65% and my speed is the same. If you want to go faster, you have to generate more power. with CS, I have a choice of increasing either or both MP and RPM. With fixed pitch, you can only push the throttle forward, and the fixed pitch will limit the maximum power you can generate. What the CS prop primarily gives is better climb and increased drag in descent if you need get down in a hurry. I've often thought a CS prop would be very beneficial in long descents. I often cruise @ 8-11k feet, and during descent, it is easy to redline the engine, so I have to remove some power, which decreases the airspeed. Yes, the CS prop will prevent the overspeed so you have one less item to watch in descent. And if you set max RPM and pull the throttle back, you can descend at 2000 fpm while staying out of the yellow airspeed arc. |
| Thread Tools | |
| Display Modes | |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Is there a minimum prop speed? | Jim Carter | Owning | 2 | June 29th 04 02:49 AM |
| Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 11:08 PM |
| Rotax 914 / Constant Speed? | Richard Riley | Home Built | 4 | February 26th 04 04:01 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
