Stiction in the yoke
Old October 25th 04, 05:25 AM
Jay Honeck
What do you guys use on your yokes? Is there anything that lasts longer
than silicone spray that (a) doesn't stain carpet, (b) doesn't stink to
high
heaven, and (c) doesn't leave particulate matter behind?
This stuff: Dupont Teflon Silicone spray lubricant.
This appears to be the same stuff I'm using.
Or does it have a special attribute that makes it more long lasting?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 25th 04, 07:54 PM
Rutger
"Jay Honeck" wrote in message news:7n_ed.301196$MQ5.292530@attbi_s52...
high
You using the DuPont brand that has both Teflon and Silicone?
There are some of these kinds of sprays that are Silicone only.
I've found that the DuPont spray with Teflon plus Silicone lasts
longer on my yokes and seat rails, and the Prestone brand of "high
viscosity formula" silicone-only spray in the bright yellow cans works
best on oleo strut legs and control surface hinges.
Old October 26th 04, 05:30 AM
Jay Honeck
Well, duh. I didn't see the Teflon part of the equation...
Sounds like a good buy. I'll pick some up and give it a whirl...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 27th 04, 02:51 AM
Jonathan Goodish
In article TgOed.298228$MQ5.193396@attbi_s52,
than silicone spray that (a) doesn't stain carpet, (b) doesn't stink to high
I believe that Piper recommends Parker O-Ring Lube for those models
where a lubricant is recommended. Parker O-Ring Lube is available at
the large aviation supply houses, but I'm not sure what makes it
different than DC4, which is what I use.
JKG
Old October 30th 04, 02:11 AM
On Wed, 27 Oct 2004 00:51:38 GMT, Jonathan Goodish
Parker O-Ring Lube (at least the tube in my tool box) is very
sticky/stringy stuff.
I really wouldn't recommend it to lubricate the yokes in a Cherokee
(we always used LPS1 or Tri-Flow)
TC
sig snip
Elite and CH Flight Sim Yoke - USB tscottme Instrument Flight Rules 3 December 22nd 10 12:34 AM
Beech dual yoke w/rams horns/color preference Dan Karshin Aviation Marketplace 1 March 28th 04 06:04 PM
CH Product Yoke with IP Trainer 6.5 Sanjay Kumar Instrument Flight Rules 2 October 10th 03 08:47 AM
MS Flight Sim 2004..............which yoke is best? TripFarmer General Aviation 0 September 29th 03 10:46 PM
Yoke grips Jose Gibert Aviation Marketplace 0 September 9th 03 04:17 AM
