![]() "PaulaJay1" wrote in message ... In article . net, "Steven P. McNicoll" writes: Who does your GTX330 report your N number to? I assumed that it is transmitted back with altitude and code. Good question about it being available to controller. As a controller, what do you know about it being displayed at your end? At my end the aircraft callsign, which can be an N-number or air carrier flight number or military callsign, is displayed only when the ARTS computer can associate it with a discrete ATC assigned squawk code. |
On Thu, 28 Oct 2004 17:32:53 GMT, "Steven P. McNicoll"
wrote: Who does your GTX330 report your N number to? I don't think they do directly report the N number, but doesn't the installer-coded Mode S octal code get downllinked to ATC whenever a mode-s enabled ground interrogator paints it, regardless of the unit's user-selectable "flight id" or 4096 code setting, thus effectively downlinking the N number because of a trivial database lookup? |
![]() "Peter Clark" wrote in message ... I don't think they do directly report the N number, but doesn't the installer-coded Mode S octal code get downllinked to ATC whenever a mode-s enabled ground interrogator paints it, regardless of the unit's user-selectable "flight id" or 4096 code setting, thus effectively downlinking the N number because of a trivial database lookup? Beats the hell out of me. The only time I get a callsign displayed is when the aircraft is squawking an ATC assigned beacon code and the ARTS computer associates that code to a specified callsign. |
"Steven P. McNicoll" wrote in message link.net...
Who does your GTX330 report your N number to? It's in the response data stream sent back to ATC from the GTX-330. However, ask any controller at any major Class B facility, and it's unlikely they're actually showing it (if their equipment even is updated to receive it). |
![]() "Dave" wrote in message om... "Steven P. McNicoll" wrote in message link.net... Who does your GTX330 report your N number to? It's in the response data stream sent back to ATC from the GTX-330. However, ask any controller at any major Class B facility, and it's unlikely they're actually showing it (if their equipment even is updated to receive it). So what's the point in sending it to ATC? |
![]() "PaulaJay1" wrote in message ... In article , (Roy Smith) writes: Unfortunately, my GTX330 reports my N number (why did they do that?). Why would you want something that tattles on you? |
OtisWinslow wrote:
: Unfortunately, my GTX330 reports my N number (why did they do that?). : Why would you want something that tattles on you? They made it an 'S' for "Secret" so you wouldn't know it was tattling on you. And since S C in the alphabet, plane owners who want the best and baddest would feel compelled up upgrade. Same with the new 406MHz ELTs. Then they can prosecute you for not waiting until 5 minutes into the hour before testing it at your annual. It'll snitch your N-number too. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
PaulaJay1 wrote:
Unfortunately, my GTX330 reports my N number (why did they do that?). Actually, it gives a mode S id number which they can look up in the registration database and map to your N number. |
![]() "Roy Smith" wrote in message ... PaulaJay1 wrote: I've filed the NASA form. By the way, what does that get me? It gets you protection from being prosecuted (not sure if that's the right legal word) for your accidental clearance bust, assuming the FAA were to initiate any action. It doesn't prevent them from violating you, it simply means that if they investigate and find you at fault they can't actually take action against your certificate. In other words, you don't lose your license, but you record will (permanently or temporarily as the case may be) reflect the results of the investigation. In other words, it doesn't prevent them from finding you guilty, it just means you won't go to jail. -cwk. |
A NASA form was intended to collect information about the national airspace
system Accordingly, for being so generous and providing information you get a pass as I understand it. |
Routine Aviation Career | Guy Alcala | Military Aviation | 0 | September 26th 04 12:33 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
Progress on Flying Car | Steve Dufour | General Aviation | 5 | December 19th 03 03:48 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
