![]() On 10-Nov-2004, tony roberts wrote: CHT's of 500/600 degrees? Definitely not. I presume he meant Fahrenheit, since he made reference to atmospheric temps in F. 350 C = 572 F. -- -Elliott Drucker |
I presume he meant Fahrenheit, since he made reference to atmospheric temps in F. 350 C = 572 F. Cylinder head temps in that range are not recommended. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Still way too high.
Low EGT's maybe? -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE In article 9DQkd.342$fc.296@trnddc09, wrote: On 10-Nov-2004, tony roberts wrote: CHT's of 500/600 degrees? Definitely not. I presume he meant Fahrenheit, since he made reference to atmospheric temps in F. 350 C = 572 F. |
Ron Rosenfeld wrote in message . ..
A friend corroded the cylinders on his Cardinal from continuous heating in just one winter. The water/acid boiled off the oil and condensed in the cylinders on the bottom side. I understand Tanis says that won't happen since they also have cylinder heat, but I'd be more than a little scared of it still happening. If nothing else minimize the preheat as much as convenient. Lycomings especially need preheat to keep the cam from scoring. The problem isn't bearings, it is all the expensive-to-repair surfaces like cylinders and camshaft/lifter surfaces that depend on a fog of oil for lubrication. Unfortunately if you push your luck on a cold start, the fog isn't developed for some time as the oil that blows over the relief valve has little access to the heat of the engine. After it warms up and sprays from the bearings etc, it does. |
![]() On 11-Nov-2004, Matt Whiting wrote: A friend corroded the cylinders on his Cardinal from continuous heating in just one winter. The water/acid boiled off the oil and condensed in the cylinders on the bottom side. I understand Tanis says that won't happen since they also have cylinder heat, but I'd be more than a little scared of it still happening. If nothing else minimize the preheat as much as convenient. Sounds like he had a defective heater. They shouldn't be gettings things above 212F which would be needed to boil off water or acid. Strictly speaking, as you point out, the term "boiled off" was probably in error. However, the point that moisture will be released as oil is heated is not. If water is being held in suspension, heating the oil and the air in the sump will cause some of that water to evaporate, and it may then condense on cold surfaces. It's like when you blow on cold glass. The moisture in your breath will condense and fog the glass, but your body temp is surely well below 212 F. The acid he speaks of is probably dissolved in the suspended water. -- -Elliott Drucker |
![]() Sounds like he had a defective heater. They shouldn't be gettings things above 212F which would be needed to boil off water or acid. Matt Water vapor will slowly come off at much lower temperatures. All it needs is to condense on something cooler than the oil. I don't recall if he had crankcase heating only, or if he had cylinder heat too. I recall the jug sitting above his desk at work, very thoroughly corroded on the bottom in one winter. |
Preheat / Pre-Oiler | Fastglasair | Home Built | 6 | November 13th 04 05:40 AM |
BRAC - The Preheat Mode | Yofuri | Naval Aviation | 17 | May 24th 04 12:47 PM |
Cold Starts | Viperdoc | Owning | 66 | February 26th 04 08:51 PM |
PIREP - Reiff Preheat Systems | Joe Young | Owning | 19 | December 14th 03 06:38 PM |
