Andrew Rowley wrote:
(John Galban) wrote: I think there's some confusion about your troubleshooting. In the original post, I (possibly by mistake) assumed that when you switched to the rough mag, the #2 EGT "shot off the scale" to the low end (i.e. cold). If you're saying it shot off the high end of the scale, this would not be the kind of reading you'd expect from a cylinder that is not firing. A weak spark rather than no spark maybe? If it's firing but less efficiently? My understanding is that this effect also causes EGTs go up when running on only one mag. I believe this is possible due to the fact that having both sparks allows the mixture to burn more quickly and thoroughly prior to opening of the exhaust valve. If the valve opens while the mixture is only partially combusted, a jet of flame will exit the exhaust port. This can greatly increase the EGT, while at the same time lowering the CHT as the same amount of heat is produced from the charge, but more of it is going out the exhaust pipe rather than being used to perform work in the cylinder. Matt |
It won't. What I'm saying is that if a plug doesn't drop out when
leaned on one mag, that's not your problem. Look elsewhere. On Mon, 22 Nov 2004 13:00:28 GMT, "Jay Honeck" wrote: Okay, after looking at all the replies, you need to stop and analyze the info given to you on the instrument. If there was a bad plug, when he switched mags, (he should have leaned it out), the temps would drop because there was no fire. Same with any other ignition part. If there was no fuel getting to the chamber, same thing. What you're seeing is a bad valve, probably exhaust. How could a bad valve on #2 work okay on "both" mags -- but not on the left mag? |
With apologees for hijacking...
I have the opposite problem, high CHT with normal EGT. Strangely enough, its also my #2 cylinder. I was thinking it was a fuel injection problem. |
![]() "Dude" wrote in message ... With apologees for hijacking... I have the opposite problem, high CHT with normal EGT. Strangely enough, its also my #2 cylinder. I was thinking it was a fuel injection problem. The problem I had with a spark plug wire a couple' months ago was on my # 2 cylinder also! |
Bad ignition lead? Excessive plug gap? Bad plug? Flashover inside
the mag? Somehow you have a marginal ignition situation on that one plug. These things aren't supposed to happen with autogas. Post us with what you find. THX |
No fuel, no fire. No fire, no big temps.
On Mon, 22 Nov 2004 15:58:22 GMT, "Dude" wrote: With apologees for hijacking... I have the opposite problem, high CHT with normal EGT. Strangely enough, its also my #2 cylinder. I was thinking it was a fuel injection problem. |
"Jay Honeck" wrote in message news:cI9od.66570$V41.11973@attbi_s52...
Our JPI EDM-700 engine analyzer may have paid for itself today. Here's the scenario: snip Your tests have pretty well narrowed it down to a plug that isn't firing (the 1st thing I look for when EGT shoots up on one cyl.). It's unlikely that the mag is firing well on all but one cyl. The most likely causes are a plug wire or the plug itself. If your mech is equipped with good testing gear, he should be able to isolate the problem pretty quickly. John Galban=====N4BQ (PA28-180) |
A dropped spark plug can crack the insulator enough to be almost
undetectable to the eye but can misfire under compression, making it hard to find otherwise. Dan "Jay Honeck" wrote in message news:cI9od.66570$V41.11973@attbi_s52... Our JPI EDM-700 engine analyzer may have paid for itself today. Here's the scenario: Mary is PIC. During her run-up, the left mag dropped a bit more than the right. She leaned it back (the usual fouled-plug procedure) and it smoothed out to within specs. Still not as smooth at the right, but with less than a 75 rpm drop. Climb out was normal, with that O-540 pulling like a tractor at over 1000 feet per minute. Life was good, especially after surviving the Wisconsin-versus-Iowa Big Ten football game... Upon leveling out, and getting everything cleaned up, I was messing around with our new CO detector, which is mounted on the pilot's-side at elbow height. (Recommendation: Don't reach across your pilot like this unless you're married to her! :-) As I was tinkering with it, my eyes were drawn to the EDM-700, which was clearly showing something amiss with the #2 cylinder. EGT was over 1630 degrees (we try to keep them under 1500), and the CHT was way low -- like in the low 200s. We tried leaning, and enrichening, and different throttle settings, but that cylinder stayed way out of line with all the others. Strangely, nothing sounded amiss at all, and the engine seemed to be performing normally. I was about to suspect something wrong with the JPI, when I suggested that we try switching to one mag, then the other, in flight. On the right mag, all was well -- but on the left mag, the engine started shaking, and the #2 EGT shot off the scale! Switching back to "both" everything smoothed out. In fact, we still could not detect anything amiss "by ear" -- but the #2 cylinder was still "out of whack" with the others. Since we were closer to our destination than home, we elected to continue on and land. On the ramp Mary did a run-up, and the #2 cylinder was still clearly not firing on the left mag. We then ran it up on "both", and leaned it severely -- again, the usual procedure for a fouled plug. After this it was better, but not perfect -- so we de-cowled the engine, and checked everything thoroughly. Other than the #2 cylinder's bottom spark plug wire being oily (actually, all the bottom wires are), I couldn't find anything amiss. I wiggled all the wires, made sure they were not bent over too sharply, checked all connections at the mags -- and then went to dinner. Of course, this bothered me throughout dinner, and I really couldn't enjoy myself. On the return flight, with me acting as PIC, I did a VERY thorough run-up, with a long, brutally leaned 2000 RPM test. Everything tested and ran fine -- and remained fine all the way home, at all throttle, prop and mixture settings. What's going on here? We burn unleaded car gas, so it seems unlikely that we had a lead-fouled spark plug (we haven't bought avgas in several weeks) -- could it be a bad plug? Or a bad spark plug wire? Can a mag fail in such a way as to only hinder a single spark plug from firing? I'm going to call my A&P tomorrow to have him check it over, but anyone got any ideas? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Bad plug. Lead fouling isn't the only reason they go bad. If it was a wire,
agressive leaning wouldn't have done anything. Alex "Jay Honeck" wrote in message news:cI9od.66570$V41.11973@attbi_s52... Our JPI EDM-700 engine analyzer may have paid for itself today. Here's the scenario: Mary is PIC. During her run-up, the left mag dropped a bit more than the right. She leaned it back (the usual fouled-plug procedure) and it smoothed out to within specs. Still not as smooth at the right, but with less than a 75 rpm drop. Climb out was normal, with that O-540 pulling like a tractor at over 1000 feet per minute. Life was good, especially after surviving the Wisconsin-versus-Iowa Big Ten football game... Upon leveling out, and getting everything cleaned up, I was messing around with our new CO detector, which is mounted on the pilot's-side at elbow height. (Recommendation: Don't reach across your pilot like this unless you're married to her! :-) As I was tinkering with it, my eyes were drawn to the EDM-700, which was clearly showing something amiss with the #2 cylinder. EGT was over 1630 degrees (we try to keep them under 1500), and the CHT was way low -- like in the low 200s. We tried leaning, and enrichening, and different throttle settings, but that cylinder stayed way out of line with all the others. Strangely, nothing sounded amiss at all, and the engine seemed to be performing normally. I was about to suspect something wrong with the JPI, when I suggested that we try switching to one mag, then the other, in flight. On the right mag, all was well -- but on the left mag, the engine started shaking, and the #2 EGT shot off the scale! Switching back to "both" everything smoothed out. In fact, we still could not detect anything amiss "by ear" -- but the #2 cylinder was still "out of whack" with the others. Since we were closer to our destination than home, we elected to continue on and land. On the ramp Mary did a run-up, and the #2 cylinder was still clearly not firing on the left mag. We then ran it up on "both", and leaned it severely -- again, the usual procedure for a fouled plug. After this it was better, but not perfect -- so we de-cowled the engine, and checked everything thoroughly. Other than the #2 cylinder's bottom spark plug wire being oily (actually, all the bottom wires are), I couldn't find anything amiss. I wiggled all the wires, made sure they were not bent over too sharply, checked all connections at the mags -- and then went to dinner. Of course, this bothered me throughout dinner, and I really couldn't enjoy myself. On the return flight, with me acting as PIC, I did a VERY thorough run-up, with a long, brutally leaned 2000 RPM test. Everything tested and ran fine -- and remained fine all the way home, at all throttle, prop and mixture settings. What's going on here? We burn unleaded car gas, so it seems unlikely that we had a lead-fouled spark plug (we haven't bought avgas in several weeks) -- could it be a bad plug? Or a bad spark plug wire? Can a mag fail in such a way as to only hinder a single spark plug from firing? I'm going to call my A&P tomorrow to have him check it over, but anyone got any ideas? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
