A Question for MU-2 Mike and other MU-2 Pilots
Old December 22nd 04, 01:14 AM
Mike Rapoport
Actually, he thought that he did.
MU-2
"Juan Jimenez" wrote in message
ink.net...
Several years ago, I spent three days in recurrent training with another
MU-2 owner-pilot who was a former military test pilot as well as a Gemini
and Apollo astronaut. If HE felt that HE needed recurrent simulator
training to fly safely, what does that say about the rest of us?
Maybe he didn't -- his insurance could have made that decision for him.
Old December 22nd 04, 03:07 AM
john smith
Mike, just how different is it flying spoilers vice ailerons?
Old December 22nd 04, 05:41 PM
Mike Rapoport
There is really no major difference except spoilers are more effective at
low speeds and don't "stiffen up" at high speeds. Spoilers also provide
effecive roll control in a stall and don't produce adverse yaw. On the MU-2
the relationship between control yoke movement and spoiler movement is such
that slightly more yoke movement is required than on most aircraft for the
same roll rate. It take people about 10hrs to get used to it. Also, In the
event of an engine failure you want to use the roll trim so that you can
neutralize the yoke because you don't want to have a spoiler sticking up.
MU-2
"john smith" wrote in message
Old December 22nd 04, 07:02 PM
Scott Skylane
Mike Rapoport wrote:
/snip/ Also, In the
Huh? Did you possibly mean *rudder* trim, or just how does the roll
trim work on that thing?
Happy Flying!
Scott Skylane
N92054
Old December 22nd 04, 07:50 PM
Mike Rapoport
There are electrically controlled ailerons for roll trim. Of course, you
also trim out the rudder forces too. The basic drill is feather the prop
then "357": three seconds of nose up elevator trim, five seconds of roll
trim and seven "handfulls" of rudder trim. There are a few more things but
none of them are critical.
MU-2
"Scott Skylane" wrote in message
/snip/ Also, In the
Huh? Did you possibly mean *rudder* trim, or just how does the roll trim
work on that thing?
Happy Flying!
Scott Skylane
N92054
Old December 23rd 04, 05:39 AM
Juan Jimenez
We got an MU-2 driver here in San Juan, he does it too.
ink.net...
MU-2
ink.net...
Gemini and Apollo astronaut. If HE felt that HE needed recurrent
simulator training to fly safely, what does that say about the rest of
us?
Old December 23rd 04, 05:42 AM
Juan Jimenez
Spoilers instead of ailerons _and_ electrically controlled ailerons for trim
on the wing? Man, what were the folks at Mitsubishi smoking the day they
came up with that one? I knew the MU-2 was different but I never realized
just how unorthodox it truly is...
ink.net...
but none of them are critical.
MU-2
/snip/ Also, In the
up.
work on that thing?
Happy Flying!
Scott Skylane
N92054
Old December 23rd 04, 06:35 AM
Mike Rapoport
I guess they were smoking the good stuff! The design was dictated by the
desire to have both a high cruise speed and short takeoff and landing
distances. They way to get both was to have a small highly loaded wing (for
high speed) and full span, double slotted fowler flaps (for short
takeoff/landing). The full span flaps left no room for ailerons so they
used spoilers. I am pretty sure that the Mitsubishi Diamond (later became
the Beechjet when Raytheon bought the design.) used the same design. The
MU-2 was much faster than competing designs with the same fusilage size and
power. The new efficiency champ is the Piaggio with its three lifting
surfaces, (actually four since the fusilage provides lift too) and high wing
loading..
MU-2
trim on the wing? Man, what were the folks at Mitsubishi smoking the day
they came up with that one? I knew the MU-2 was different but I never
realized just how unorthodox it truly is...
ink.net...
MU-2
/snip/ Also, In the
can neutralize the yoke because you don't want to have a spoiler
sticking up.
Happy Flying!
Scott Skylane
N92054
Old December 23rd 04, 04:30 PM
Peter MacPherson
Mike,
You seem to be a fan of the Piaggio. I don't know much about it but it
is different looking. What is it about the Piaggio that you like so much?
At it's price point you could get a jet. Does it have a higher useful load,
longer range than a comparable priced jet? Just curious.
Pete
nk.net...
(for high speed) and full span, double slotted fowler flaps (for short
wing loading..
MU-2
ink.net...
you also trim out the rudder forces too. The basic drill is feather the
prop then "357": three seconds of nose up elevator trim, five seconds of
roll trim and seven "handfulls" of rudder trim. There are a few more
things but none of them are critical.
MU-2
/snip/ Also, In the
sticking up.
Happy Flying!
Scott Skylane
N92054
Old December 24th 04, 03:26 AM
Mike Rapoport
It is an elegent solution. Instead of having a horizontal stabilizer
producing downforce and the wing having to overcome that as well as the
weight of the plane, the Piaggio uses three "wing" surfaces that all produce
lift. In addition, the fusilage is curved over its entire length and
produces lift as well. Most pressurized fusilages are a tube with a couple
of cones riveted on. I don't think that there is a jet that has close to
the Piaggios cabin size for anywhere near the money. It is also very quiet.
It has more range, cabin room and consumes much less fuel than anything in
the same price range. The new Avanti II with glass cockpit, reduced empty
weight and increased gross weight will have even greater advantages over
comparable jets. It is also beautiful.
MU-2
"Peter MacPherson" wrote in message
news:doCyd.4870$k25.4775@attbi_s53...
Mike,
load,
Pete
nk.net...
and power. The new efficiency champ is the Piaggio with its three lifting
wing loading..
MU-2
ink.net...
the prop then "357": three seconds of nose up elevator trim, five
seconds of roll trim and seven "handfulls" of rudder trim. There are a
few more things but none of them are critical.
MU-2
/snip/ Also, In the
sticking up.
Happy Flying!
Scott Skylane
N92054
