![]() "Rosspilot" wrote: EDM 700 works great for me. Just upgraded it with fuel flow - very nice. How does the "fuel flow" option work? Where is the sensor and what does it measure? It's a paddle wheel-type transducer that is cut into a fuel line. It measures actual gallons per hour. I bought that option on my EDM 700 and I'm glad I did. It is quite accurate; if it says I've burned 40 gallons, the pump will say 39 when I top off, a 2.5% error. The unit has a software "K factor" I could change to tune that out, but since it errs on the "safe" side I haven't bothered. I'm blessed with one of the few Cessnas that have accurate fuel gauges, so I'm able to cross check them with the EDM 700 and vice versa. The fuel flow reading is also a useful leaning tool. I know the fuel flows for my typical altitudes and power settings, so there's no hunting around with the mixture control when I level off in cruise. The EDM 700 is also RS-232 interfaced to my B/K GPS, so I get nmpg, range, endurance, etc. on both units--very cool. -- Dan C-172RG at BFM |
![]() "Rosspilot" wrote in message ... I am considering installing an engine monitor in my Skyhawk . . . and have narrowed the search to these two selections: Gem610 and JPI EDM-700 I looked at both of these and went with the JPI due to it's far better (more better?) usability and functionality. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Hi Rosspilot
I'm interested to know why you eliminated the EI analyzer from your list. It is a great piece of equipment from a great company. I fly the same plane as you and my EI monitors all 6 CHT's, all 6 EGT's, Oil temp, carb temp, and I still have room to add another probe - currently considering outside air temp - I don't think that fuel flow is all that beneficial - I know it's about 8 GPH and yes I do check the caps to ensure that they are not leaking (once bitten . . . ) If you haven't checked it out, don't discount it Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE In article , ospam (Rosspilot) wrote: I am considering installing an engine monitor in my Skyhawk . . . and have narrowed the search to these two selections: Gem610 and JPI EDM-700 Any pireps, recommendations, anecdotes, or other feedback? Thanks in advance . . . www.Rosspilot.com |
![]() I'm interested to know why you eliminated the EI analyzer from your list. Thanks, Tony . . . looking in to it. www.Rosspilot.com |
![]() Rosspilot wrote: Any pireps, recommendations, anecdotes, or other feedback? I will not consider any JPI product because of their despicable behaviour to EI some years ago. George Patterson The desire for safety stands against every great and noble enterprise. |
![]() I will not consider any JPI product because of their despicable behaviour to EI some years ago. I'm unaware of this. What did they do? I just got another report from a friend who has the JPI but said it comes with cheap (and innacurate) washer-type probes that fit between the plugs and cylinder heads . . . said the better probes are the screw-in types that go in the pre-drilled holes on the head . . . recommended Tanis probes. Said once he put those in, the JPI was perfect. www.Rosspilot.com |
![]() Rosspilot wrote: I will not consider any JPI product because of their despicable behaviour to EI some years ago. I'm unaware of this. What did they do? The other company (IIRC, it was EI) had a product on the market called "FuelScan". It was trademarked. One of the features of the JPI unit is it operates as a "scanner" (no trademark), and this was documented in their literature. They decided that they didn't like the competition from the other firm, but they really *did* like the product name. So they filed a trademark infringement suit. Never mind that it was the *other* firm that held the trademark. The other company could not afford to defend the suit. Now JPI sells the "Fuel Scan" and owns the trademark. Ron Natalie probably remembers more details than I. George Patterson The desire for safety stands against every great and noble enterprise. |
The spark plug washer probes are not inaccurate. You will always
read a higher temperature at the sparkplug than at the screw in probe location because the temperature is really higher at the sparkplug location. The sparkplug mount will also respond faster since there is less mass of metal from there to the fire to slow the response. If you don't believe this take any brand of thermocouple meter and make two thermocouples out of the SAME length of thermocouple grade wire and mount the thermocouples at both locations then measure the result. You will also find that the "piggy back" mount where you already have a screw in heater or a factory CHT probe at the probe hole mount you will read several degrees lower. It is basic physics 101. I have a EI scanner and I would not buy another one since the EI scanner I have requires a UNGROUNDED thermocouple probe. I have to replace an EGT probe every year or two since oil wicks into the probe and forms a conductive carbon path to ground. This will cause the EGT reading on that cylinder to read higher than it should. This can be verified with an ohm meter. EI may have changed the design since I bought mine but DO NOT buy a scanner that requires UNGROUNDED probes or you too will be replacing probes every year or so because no matter what they say about how well sealed they are the probes will wick oil and ground out. John On 26 Dec 2004 13:31:52 GMT, ospam (Rosspilot) wrote: I will not consider any JPI product because of their despicable behaviour to EI some years ago. I'm unaware of this. What did they do? I just got another report from a friend who has the JPI but said it comes with cheap (and innacurate) washer-type probes that fit between the plugs and cylinder heads . . . said the better probes are the screw-in types that go in the pre-drilled holes on the head . . . recommended Tanis probes. Said once he put those in, the JPI was perfect. www.Rosspilot.com |
I've had the edm 700 in my skyhawk for a few years and it's fine. My only
gripe is that the engine data can only be downloaded to a Palm or laptop. It doesn't download to a Pocket PC, which I happen to have. Steve "Rosspilot" wrote in message ... I am considering installing an engine monitor in my Skyhawk . . . and have narrowed the search to these two selections: Gem610 and JPI EDM-700 Any pireps, recommendations, anecdotes, or other feedback? Thanks in advance . . . www.Rosspilot.com |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
