![]() "Robert M. Gary" wrote in message oups.com... I guess my question is; do all planes generate about 13.6v with accessories on? I also teach in a large variety of planes, but none have a volt reader in the panel. When I was reading your original post, I thought I read 12.6. I was reading what I thought was abnormal, but now looking at it, I see I was not. ?.? 13.8 volts is considered normal, so 13.6 is not so bad after all. Are you getting any warnings, or anunciatiors at the 13.6? The next question is, are you able to complete a flight with everything on, and come back and still be reading the same battery voltage (engine off) that you started with? If so, no worries! -- Jim in NC |
There are six diodes in the common three-phase alternator.
Dan |
My EDM700 (Arrow 200) has shown 13.5-13.7 in flight for a couple of
years. It recently dropped to 12.1, which I've interpreted to mean the 4-year old battery is shot. Just replaced the battery but haven't done test flight yet. |
In rec.aviation.owning Robert M. Gary wrote:
: When I turn on a lot of accessories on my Mooney F '76 I can drop the : bus voltage down to around 13.6. My A&P says 13.6 is normal with : accessories on. Does this sound right? Don't forget that the charging voltage for a lead-acid battery is *supposed* to be modified by ambient temperature, with a higher voltage at lower temps. This is commonly done with a thermistor in the voltage regulator. Even the mechanical (vibrating relay) regulator in my 1977 Datsun has temperature compensation. That said, 13.6V is probably OK. If you check the volts on the battery terminals you'll probably get a little more than the 13.6V on the avionics bus, because the battery is wired to the alternator with heavier wires. -- Aaron C. |
On Tue, 28 Dec 2004 17:43:57 +0000 (UTC), Aaron Coolidge
wrote: snip Don't forget that the charging voltage for a lead-acid battery is *supposed* to be modified by ambient temperature, with a higher voltage at lower temps. This is commonly done with a thermistor in the voltage regulator. Even the mechanical (vibrating relay) regulator in my 1977 Datsun has temperature compensation. Good point, the battery dudes suggest a difference in regulated charging voltage with varying battery operating temperatures, which can vary from ambient temps. That said, 13.6V is probably OK. If you check the volts on the battery terminals you'll probably get a little more than the 13.6V on the avionics bus, because the battery is wired to the alternator with heavier wires. Another good point, voltage drop between a GA aircraft main bus and the avionics bus is not uncommon. Regards; TC |
When I turn on a lot of accessories on my Mooney F '76 I can drop the bus voltage down to around 13.6. My A&P says 13.6 is normal with accessories on. Does this sound right? How dare you doubt the word of your A&P? Don't you know that every A&P candidate is individually interviewed by an FAA inspector before he's even allowed to take the written test, and those who are unworthy are weeded out? ( ![]() Seriously, 13.6 volts under load is not unusual. In theory, the system should be 14 V, and you are allowed a drop of 2% of that to the main bus, for a minimum voltage of 13.72 V. Now, how exactly do you think your 20+ year old (by design) regulator holds the voltage? Think it might be 0.1 V off? Because that's all it would take. Think it's absolutely insensitive to load (a true voltage regulator with zero temperature and current dependence)? Think again. That level of stability is not necessary and generally not present. Typically the regulator will give you 14 +/- 0.2 V. At 13.6V, your battery will charge just fine and your accessories will run. So watch it, and as long as it stays where it is, don't worry about it. Michael |
C182 - Intermittent Alternator | WinstonCup | Owning | 9 | November 12th 04 12:22 AM |
no RPM drop on mag check | Dave Butler | Owning | 19 | November 2nd 04 02:55 AM |
Cessna 210 charging problem | John Clonts | Owning | 9 | July 14th 04 03:08 PM |
Normal EGT - Very Low CHT | markjen | Owning | 7 | March 4th 04 01:54 PM |
Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 03:24 AM |
