On 2 Jan 2005 16:29:32 -0800, "Gene Seibel" wrote:
I have a 1966 Cherokee 180 with fixed pitch prop. I have noticed some oil streaks on the back plate of the prop spinner, apparently seeping out between the prop and flywheel. Anyone have an expereince with this? Is there a plug in the front the hollow (I assume) crankshaft that could be leaking? Is this a common problem? Thanks for any info. There is a seal at the front of the engine where the crankshaft exits. It's glued in place and the glue can come loose. Replacing it takes a few hours, as the prop needs to be removed and replaced, but shouldn't be a big deal for an experienced technician (if that's what's causing the leak). Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
oil leak question | Dick | Home Built | 18 | November 19th 04 03:14 PM |
~ DICK GRILLED FOR CIA LEAK - CAN YOU SAY PRISON?! ~ | ~ THE CHOKING CHIMP ~ | Military Aviation | 0 | June 6th 04 05:34 AM |
Pazmany PL2 strut leak | moni nut | Home Built | 1 | April 27th 04 02:24 AM |
oil leak fixed - breaking in new cylinders | Michael 182 | Owning | 24 | September 23rd 03 12:36 PM |
Oil Leak in TR182 | Michael 182 | Owning | 2 | August 17th 03 07:13 PM |
