The Home Depot tool looks slightly less cheap than the Lowes tool. It's
red, the Lowes is green. In both stores I had to search for the tool myself, calling ahead with the part number and asking salesmen in the store didn't help. In both cases a flashlight would have helped in the search. I found them far from the tool cribs, in the area where they sell cable, tucked into an obscure cubby hole on a bottom shelf. Your results may vary. Bruce A. Frank wrote: I once did the same thing with a pair of bolt cutters. It worked and the go/no-go gauge said it was correct, but it created a slight half moon shape on the sleeve. I also took a cheap bolt cutter and brazed parts of one of the bolt together cheapo tools to the jaws...also worked correctly, but it looked strange. When I bought the cheapo tool crimping tool from Home Depot I finally had an acceptable tool...after some minor adjustment. It is likely the Lowe's tool is exactly the same as the one from Home Depot. abripl wrote: I made one out of a pair of chain cutters with a little bit of welding and grinding to get the correct opening size. -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| -- J Kimmel www.metalinnovations.com "Cuius testiculos habes, habeas cardia et cerebellum." - When you have their full attention in your grip, their hearts and minds will follow. |
Nicopress Swaging Tool - Availability | Gary T. Ciampa | Home Built | 42 | February 11th 05 05:49 PM |
Nicopress Swaging Tool - Availability - Retraction of Recommendation! | Gary T. Ciampa | Home Built | 0 | February 6th 05 12:00 AM |
Papco #600 -- Roto-Master Flaring Tool | Michael Burton | Aviation Marketplace | 0 | October 27th 03 05:35 PM |
FS: Papco #600 Flaring Tool | Michael Burton | Home Built | 0 | October 27th 03 05:26 PM |
Machine Tool Co. Bankruptcy Sends Ripple Through JSF Program | huuto | Military Aviation | 3 | July 29th 03 05:59 AM |
