Archer Tach Red Arc
Old January 18th 05, 01:30 PM
Greg Esres wrote:
: Does anyone know of any legitimate reason for an Archer to have a red
: arc, other than max RPM?
The reason is for resonance issues with the Sensenich 76" (EMS8 or whatever)
prop and a Lycoming O-360-A3A (hollow-crank) engine. Our 140 has the Avcon engine
upgrade to 180 HP and has the limitation specified in the STC and the supplemental POH
that came with the STC.... but *only* if the engine is a -A3A. If it's a -A4A, it's
got a solid crank and doesn't require the limitation.
I'd say check the logbooks for propeller model and engine model suffix. I
believe the wording is, "Avoid prolonged cruise power within the 2150-2350 rpm range"
I think they discovered this issue shortly after the -180's came out, so I'm
surprised that an Archer POH doesn't mention it.
-Cory
* Cory Papenfuss *
Old January 18th 05, 02:44 PM
Nathan Young
On Tue, 18 Jan 2005 02:40:13 GMT, Greg Esres
A student has an Archer II that has a red arc painted on the glass of
the tach between 2150 and 2350 RPM. The POH makes no mention of a red
arc.
I'm thinking that either the tach came out of an Arrow (which has a
red arc in this range) or some A&P confused the Archer with an Arrow
and painted it on.
The older Cherokee 180s had the O-360-A3A engine with the hollow crank
shaft. There was a prohibited RPM range at approx 2150-2350.
I would bet the tach is out of one of these 180s.
-Nathan
Old January 18th 05, 08:34 PM
John Kunkel
"Greg Esres" wrote in message
arc.
and painted it on.
I'm surprised the arc is red (prohibited), it should be yellow (caution) to
warn against continuous operation in that rpm range.
It's pretty hard to accelerate from idle to max rpm, without passing through
the range that is red arced on the tach.
Old January 18th 05, 09:33 PM
(caution) to
On most of the original planes with this marking, I remember that it
was a yellow marking. Over the last several years, I've noticed the
red arc popping up in the same range. I just figured that either
someone got the color wrong, or the spec. was changed by Piper.
through
That's correct. The only reason I could figure they'd change it to
red would be to emphasize that you really don't want to spend time with
your engine running in this range. I could see pilots confusing it
with the yellow arc on the airspeed indicator. In smooth conditions
it just fine to operate in the yellow arc.
Old January 20th 05, 01:48 AM
Jerry
There was an AD in effect for a few years that applied the RPM restriction
even to solid-cranshaft Archers. It was rescinded later. I think our Archer
had ugly red paint on the tach for a year or so in the early 90's.
Jflyer
arc.
and painted it on.
Tachometer or Tach Cable Rich Owning 14 October 14th 04 02:54 AM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 03:33 AM
Wayward Tach O. Sami Saydjari Owning 7 February 6th 04 01:27 AM
Tach Vs. Hobbs Time John Roncallo Owning 33 January 7th 04 12:42 AM
Need new PA28 tach Michael Isaksen Owning 2 October 2nd 03 03:27 PM
