Should I consider this plane - weird engine history
Old February 2nd 05, 08:16 PM
Jay Masino
kage wrote:
It wasn't a "Bottom overhaul." It was a prop strike inspection. The case
would need to be overhauled along with at least the oil pump, plus other
stuff they don't touch.
That's what I was thinking. Actually, I think a prop strike inspection
on a Lycoming mostly consists of inspecting the gears inside the accessory
case, but they may have magafluxed the crank, too. Otherwise, they just
reassembled it with the same parts they disassembled it with.
--- Jay
__!__
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old February 2nd 05, 10:34 PM
Jay Masino wrote:
: case, but they may have magafluxed the crank, too. Otherwise, they just
: reassembled it with the same parts they disassembled it with.
Except some things which must be replaced... like connecting rod bolts.
Main bearings?
Seems pretty silly to me to not do the slight bit more work to get an
overhaul... basically just some magnafluxing of the steel parts is all.
-Cory
* Cory Papenfuss *
Old February 3rd 05, 12:18 AM
nuke
Count it as a near runout, value the plane and engine accordingly.
Been there, done that. Bought a plane with 1500 SMOH and way too many years,
had a prop strike teardown 500 hours and 4 years before I bought it. Ran
strong, had a couple of fresh overhauled cylinders, clean oil screens and oil
analysis came back great. Engine didn't leak and was clean enough to eat off of
and had flown about 300 hours in the last 1.25 years.
Less than a hundred hours into my ownership, I found bearing material in the
sump screen. Off to the overhaul shop.
The teardown revealed a bearing failure as the source of the metal. Cylinders
and cam, lifters and so on looked pretty good, which means all my inspections
were fine. Case needed a minor re-work, probably the source of misalignment of
the bearing that caused it to fail in about 600 hrs of flying time.
Just because it has been apart doesn't make it as good as an overhaul.
If you count it as a
Dr. Nuketopia
Sorry, no e-Mail.
Spam forgeries have resulted in thousands of faked bounces to my address.
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
