#11
I thought the Skycraft's STC required the removal of the nose light..
Nope. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I'm in the midst of having these lights installed, (they are the cut-in-the-leading-edge landing lights) and we come to a fork in the road with regards to the wiring. The kit comes with a split L/R on/off switch, and two 10 amp circuit breakers. This means that my existing landing light switch stays in the panel, controlling the nose light only, while this new switch has to go in the panel somewhere, separately controlling EACH wing light. Having seperate switches for each lamp would allow you to spread out the high-current load of each lamp as it turns on. I'll admit to not knowing how significant this turn-on load is, just a thought from a person with a dangerous amount of knowledge. Dave |
high-current load of each lamp as it turns on. I'll admit to not knowing how significant this turn-on load is, just a thought from a person with a dangerous amount of knowledge. I think the combined amperage of all three lights is something like 24 amps. I have no idea if that's considered "a lot" for a Cherokee 235's electrical system. Can anyone with this knowledge chime in, please? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I think the combined amperage of all three lights is something like 24 amps. I have no idea if that's considered "a lot" for a Cherokee 235's electrical system. Can anyone with this knowledge chime in, please? I don't think it has anything to do with a 235's electrical system vs. any other plane. The issue is whether the wire gauge is sufficient for that much current and/or whether the switch contacts can handle that much current. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Jay, I have RMD wingtip lights on my Arrow, plus the nose bowl so I
think my total amperage will be the same as yours. I have the 2 wingtip lights on a single separate rocker switch in the group. The plane was this way when I bought it, so I don't know what got displaced. My strobe switch is way out in right field, and the autopilot is in left field, with a separate avionics switch, so maybe one of those. I like having the tip lights by themselves. They last a lot longer than the one on the nose bowl so I often use them routinely when flying around Chicago. I haven't had any problems in 5 years with the single switch, so if the switch, breaker, and wiring will all support the amperage draw a single circuit should be fine. |
![]() wrote: snip I have the 2 wingtip lights on a single separate rocker switch in the group. The plane was this way when I bought it, so I don't know what got displaced. The standard switch bank order (from left to right) was : Master, Fuel pump, Landing light, Beacon (strobe), Pitot heat. My strobe switch is way out in right field, and the autopilot is in left field, with a separate avionics switch, so maybe one of those. Sound like whomever did your installation displaced the beacon/strobe switch. John Galban=====N4BQ (PA28-180) |
Landing Light CB | Hankal | Owning | 25 | August 25th 04 02:22 AM |
Would a 3 million Candlepower spotlight make a good landing light? | Legrande Harris | Home Built | 6 | June 15th 04 06:32 AM |
C-172 landing light switch | JFLEISC | Owning | 10 | May 5th 04 11:05 PM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
