Owner Change/rotate spark plugs?
Old February 11th 05, 12:53 PM
Jon A.
If you're talented enough! Don't forget your torque wrench, new
gaskets and antiseize compound.
On Fri, 11 Feb 2005 00:13:52 -0500, "Victor J. Osborne, Jr."
Can an owner do this?
TIA, {|;-)
Victor J. (Jim) Osborne, Jr.
Old February 11th 05, 03:09 PM
Copper gaskets can be annealed by heating red hot and quenching in
cold water. They can be reused three or four times this way until their
diameter gets too large from being squashed. Using used, unannealed
gaskets can result in small leaks, and a leaking plug can carry carbon
into the threads and make it really hard to remove without damaging the
head's thread socket.
Dan
Old February 11th 05, 06:09 PM
Rip
No, copper is annealed by quenching rapidly.
Aaron Coolidge wrote:
: Copper gaskets can be annealed by heating red hot and quenching in
: cold water.
That's how you harden them.
To anneal them, heat them red hot and let them cool gradually.
Old February 13th 05, 01:14 AM
Aaron Coolidge
Rip wrote:
: No, copper is annealed by quenching rapidly.
OK, you got me there. As it turns out, copper may be annealed by aircooling
or quenching. To harden copper requires a temperature decrease of about
10,000 degC per second which isn't going to happen if you drop 'em in water.
By the way, you'll never get copper hot enough to anneal with a propane torch.
Oxy-propane, yes.
Aaron C.
Old February 12th 05, 12:56 AM
Jon A. wrote:
And you're posting this during a discussion of the question whether or
not an owner can change their own plugs.
Horse - - - Cart
Cart - - - Horse
So that means that means that wheher the gaskets are annealed or
reused without annealing is irrelevant? That the owner wouldn't benefit
by knowing about using new or annealed gaskets? Come on.
Dan
Old February 12th 05, 04:45 AM
John Clonts
wrote in message oups.com...
Horse - - - Cart
Cart - - - Horse
Dan
Well, I have learned from elsewhere in this thread that NEW gaskets are DEFINITELY the way to go since there is
debate as to whether the proper treatment of used gaskets is to include cold water quenching or ambient air
cooling...
Cheers!
John Clonts
Temple, Texas
N7NZ
Spark plug question: Massive electrode or fine wire? Peter R. Owning 9 February 4th 05 02:03 AM
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
Bougies blindées BG à vendre/BG spark plugs for sale stef General Aviation 0 May 14th 04 04:57 PM
Color of spark plugs john smith Owning 5 March 2nd 04 03:08 AM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
