I don't know what the prices are now, but full-motion sims such as Larry
describes go for several hundred dollars an hour...I used to get an hour in a 737 sim for Christmas every year from a buddy who worked at a sim center. Bob Gardner "Benjamin Gawert" wrote in message ... BTIZ wrote: define "real" simulators... A fully complete cockpit made of the cockpit parts of the real aircraft, with front visual system, force feedback, and some simulation of the g-forces pressing the pilot into the seat. A simulator that shows the exactly same behavior the real aircraft shows... there are varying degrees "classes" beyond the desktop PC, most are usable for IFR training, but as mentioned in a previous post, you need a CFII with you to log the training, just practice by your self, although good experience is not creditable towards log book hours or currency requirements. Right. I just want to know if I would log the sim hours if it would make any sense when having a PPL. Even if they at least count when making the CPL somewhen... Benjamin |
![]() "BTIZ" wrote in message news:jiFPa.717$Je.481@fed1read04... define "real" simulators... there are varying degrees "classes" beyond the desktop PC, most are usable for IFR training, but as mentioned in a previous post, you need a CFII with you to log the training, just practice by your self, although good experience is not creditable towards log book hours or currency requirements. The only device which requires a CFII to make it loggable is a "PCATD," which is a personal computer aviation training device -- basically a computer with a yoke and rudder pedals. A PCATD requires a CFII in order for the time to count toward the instrument rating. The next step up is a "Flight Training Device" and can be graded from Level 1 through Level 6 depending on the degree of realism of the cockpit and visual display and controls. Even an older Level 1 Flight Training Device which has only an instrument panel and no visual display can be used toward IFR currency. It is acceptable for a CFII to administer an IPC in a flight training device; however, it is also acceptable for a pilot to use solo time in the flight training device toward instrument currency. A flight training device can range anywhere from instruments only with no motion to full-motion with 180-degree visual projection, a realistic cockpit, advanced avionics, and sophisticated failure scenarios. The next step up would be to a Level A through D "Simulator".. these are highly realistic motion-based simulators which almost always cost in the millions or at least high 6 figures.. it would be extremely unusual to use a Level A through D "Simulator" for piston general aviation training. My "simulator" which will be installed next week, for example, is actually a full-motion Level 3 Flight Training Device. It will indeed be creditable as logged time and for currency purposes. However, the time will count as "Flight Training Device" time and "Simulated Instrument Time" and not as airplane time. -- Richard Kaplan, CFII www.flyimc.com |
