Interesting question. Without trying to look it up, I would say that it is your responsibility to remain clear or make contact with Mc Entire Tower when VFR. No. How can you remain clear when you are right in the middle of it? I realize that it is my responsibility to remain clear or have two way communications. Well, I had two way communications with ATC -- I was in communications with Shaw Approach. Does that count? Yes. You don't have a clearance of any sort so your path of flight as well as altitude is at your discretion. If you are in Class B,C Yes. ,D, No. then the controller can give you vectors and altitudes but doesn't necessarily have to under FF. What? In class B you are essentially IFR and will be separated from everyone else. In class C you may or may not be separated. Some class C facilities make their controllers separate all aircraft from all others, most don't. In class D you get nothing except a generic traffic call. An example would be where you have established flight following and announced that you are at 3,000ft. Then over Mc Entire, you decide to descend to 2,000 feet. Nothing prevents you from to doing so under FF but you would be compelled to contact the tower to enter the Class D. No, absolutely not. It is 100% the responsibility of approach to contact the tower. And your altitude isn't relavant. As an example at my tower/TRACON the TRACON owns the airspace up to 12,000. We let the tower have about 1500 feet AGL. That doesn't mean however that the TRACON can bring overflights right over the airport at 2000 AGL without coordinating with the tower. Any airplane that the TRACON is working that is going over the airport has to be coordinated with the tower, even if you are at 12,000, because the tower has automatic releases for all departures. Same thing if Salt Lake is working a VFR overflight at 12,500 or an IFR overflight at 13,000. He has to call me to point out that traffic to me. Now you would have to know what kind of agreement between the tower and its approach facility is in effect. Of course you have no way of knowing that. That's why overflights are coordinated with the tower from the approach controller. |
"Newps" wrote in message news:1JeYa.55203$cF.19683@rwcrnsc53... No, absolutely not. It is 100% the responsibility of approach to contact the tower. And your altitude isn't relavant. As an example at my tower/TRACON the TRACON owns the airspace up to 12,000. We let the tower have about 1500 feet AGL. That doesn't mean however that the TRACON can bring overflights right over the airport at 2000 AGL without coordinating with the tower. Any airplane that the TRACON is working that is going over the airport has to be coordinated with the tower, even if you are at 12,000, because the tower has automatic releases for all departures. Same thing if Salt Lake is working a VFR overflight at 12,500 or an IFR overflight at 13,000. He has to call me to point out that traffic to me. No he doesn't. |
Maule Driver wrote:
Interesting question. Without trying to look it up, I would say that it is your responsibility to remain clear or make contact with Mc Entire Tower when VFR. Maule Driver, This was the subject of a long thread some time ago. The bottom line is: It is NOT the responsibility of a pilot receiving radar services to coordinate with each surface area he flies through. (if he is landing in that surface area, ordinarily radar services would be terminated prior to entering it) The facility providing the radar services is supposed to coordinate, and maintaining contact with them counts under the communication requirement of the FARS. I have heard before that there are some areas where this does not happen, but it is spelled out quite clearly in the controller's regulations (7110.65) it is supposed to. The particular situation described is problematic, because the facility providing radar services terminated them w/out a handoff. In that circumstance, I personally would probably contact the tower immediately, including in my call up something like "I had radar services from XXXX, I assume they coordinated with you". (because that's what's supposed to happen). Cheers, sydney |
"Sydney Hoeltzli" wrote in message
... Maule Driver wrote: Interesting question. Without trying to look it up, I would say that it is your responsibility to remain clear or make contact with Mc Entire Tower when VFR. The bottom line is: It is NOT the responsibility of a pilot receiving radar services to coordinate with each surface area he flies through. (if he is landing in that surface area, ordinarily radar services would be terminated prior to entering it) The facility providing the radar services is supposed to coordinate, and maintaining contact with them counts under the communication requirement of the FARS. Makes sense and I stand corrected. Thanks. I was trying to think through the meaning of 'radar services' and 'flight following'. I was thinking that you are not bound to maintain a heading or an altitude while under FF (right?). So that would mean that you can deviate from your reported heading and altitude and enter Class D without necessarily notifying the controller. Or am I way off base here and need to do some reading? The particular situation described is problematic, because the facility providing radar services terminated them w/out a handoff. In that circumstance, I personally would probably contact the tower immediately, including in my call up something like "I had radar services from XXXX, I assume they coordinated with you". (because that's what's supposed to happen). Really puts the focus on situational awareness when that happens! |
Maule Driver wrote:
I was trying to think through the meaning of 'radar services' and 'flight following'. I was thinking that you are not bound to maintain a heading or an altitude while under FF (right?). So that would mean that you can deviate from your reported heading and altitude and enter Class D without necessarily notifying the controller. Sure, you can change heading and altitude without necessarily notifying the controller, but situational awareness and common sense do enter into it. The radar controller will make a decision on whether or not he needs to coordinate based on your altitude and direction of flight. If you need to change either or both, and that change might put you in a surface area your original altitude and heading would keep you clear of, it may not be a regulatory requirement to communicate your intentions but it only makes sense IMO. The particular situation described is problematic, because the facility providing radar services terminated them w/out a handoff. In that circumstance, I personally would probably contact the tower immediately, including in my call up something like "I had radar services from XXXX, I assume they coordinated with you". (because that's what's supposed to happen). Really puts the focus on situational awareness when that happens! Well, Steve may be correct that the communication requirements have been met, but I'd personally contact the tower in those circs, just in case there was a need to communicate; IME it takes several minutes to establish communication and radar contact with a busy approach facility, and I really don't want to be distracted from keeping a sharp look-out when I'm close to an airport, either. Cheers, Sydney |
"Maule Driver" wrote in message .com... Interesting question. Without trying to look it up, I would say that it is your responsibility to remain clear or make contact with Mc Entire Tower when VFR. No. It is the responsibility of the radar controller to coordinate the transition of Class D airspace. FAA Order 7110.65N Air traffic Control Chapter 2. General Control Section 1. General 2-1-16. SURFACE AREAS a. Coordinate with the appropriate nonapproach control tower on an individual aircraft basis before issuing a clearance which would require flight within a surface area for which the tower has responsibility unless otherwise specified in a letter of agreement. REFERENCE- FAAO 7210.3, Letters of Agreement, Para 4-3-1. 14 CFR Section 91.127, Operating on or in the Vicinity of an Airport in Class E Airspace. P/CG Term- Surface Area. b. Coordinate with the appropriate control tower for transit authorization when you are providing radar traffic advisory service to an aircraft that will enter another facility's airspace. NOTE- The pilot is not expected to obtain his/her own authorization through each area when in contact with a radar facility. c. Transfer communications to the appropriate facility, if required, prior to operation within a surface area for which the tower has responsibility. REFERENCE- FAAO 7110.65, Radio Communications Transfer, Para 2-1-17. FAAO 7110.65, Surface Area Restrictions, Para 3-1-11. FAAO 7110.65, Application, Para 7-6-1. 14 CFR Section 91.129, Operations in Class D Airspace. You don't have a clearance of any sort so your path of flight as well as altitude is at your discretion. If you are in Class B,C,D, then the controller can give you vectors and altitudes but doesn't necessarily have to under FF. The radar controller can issue vectors to VFR aircraft in Class B and Class C airspace, but not in Class D airspace unless it is also a TRSA. |
Arden Prinz wrote:
Sorry for so many questions... I just want to do things 100% right (well at least 90% of the time :-) )! First things first... Have you filed out your Aviation Safety Reporting System form yet? Go to: http://asrs.arc.nasa.gov/ |
john smith wrote in message ...
Arden Prinz wrote: Sorry for so many questions... I just want to do things 100% right (well at least 90% of the time :-) )! First things first... Have you filed out your Aviation Safety Reporting System form yet? Go to: http://asrs.arc.nasa.gov/ Thank-you for the suggestion. I have never submitted one of these. That's a good idea and I may do just that. I just printed out the form. I was hoping that maybe I didn't do anything wrong. Arden |
"Arden Prinz" wrote in message
om... john smith wrote in message ... Arden Prinz wrote: Sorry for so many questions... I just want to do things 100% right (well at least 90% of the time :-) )! First things first... Have you filed out your Aviation Safety Reporting System form yet? Go to: http://asrs.arc.nasa.gov/ Thank-you for the suggestion. I have never submitted one of these. That's a good idea and I may do just that. I just printed out the form. I was hoping that maybe I didn't do anything wrong. I don't think you entered class D improperly. But ASRS forms are helpful to NASA even if you did nothing wrong. --Gary Arden |
| Thread Tools | |
| Display Modes | |
| For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 06:18 AM |
| Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 23rd 04 12:19 AM |
| Which post-WW2 combat aircraft have not been used in combat? | Kirk Stant | Military Aviation | 96 | December 10th 03 04:03 PM |
| Hispanic Hero Recalls Experiences | Otis Willie | Military Aviation | 0 | September 30th 03 11:02 PM |
| #1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 04:04 AM |
