FAR:Safety Pilot & High Performance/Complex?
Old August 8th 03, 12:55 AM
journeyman
On Thu, 07 Aug 2003 22:41:21 GMT, Robert Moore wrote:
You are confusing "High Performance" and "Complex". The C-182 is
both complex and high performance. The C-177RG is only complex.
Surely you mean the C-182RG is both complex & high perf. The C-182 is
only "high performance". The C-177RG is, of course, "complex" but not
"high performance".
A "complex" endorsement is good for all complex airplanes, a "high
performance" endorsement is good for all types of high performance
airplanes.
True.
Morris
Old August 8th 03, 01:25 AM
Robert Moore
C-182 is only "high performance". The C-177RG is, of course,
"complex" but not "high performance".
Yep! A slip of the fingers. :-)
Bob Moore
Old August 8th 03, 01:43 AM
JerryK
You can act as safety pilot without having the high performance or complex
endorsements. All you need is to have at least a PPC and be rated in the
a/c. (91.109(b)(1)).
Here is a wrinkle what if you are rated in category and class, but not
current? Ex. you have not landed in class and cat lately. Can you still
act as safetly pilot?
Old August 8th 03, 02:33 AM
FryGuy
Ok, I think I understand now and I'm going to try and summarize what I've
gathered from reading the other posts in this thread. Thanks for
everyone who answered me even though I know this dead horse has been
beaten in the past. Please let me know if I'm wrong.
1) I have a friend who needs to go practice some IFR approaches to
stay current. I am a private pilot ASEL. I'm pretty sure that it is
not a problem with me being his safety pilot but he told me I can log
the time PIC. Is this correct?
Yes, the pilot flying in simulated instrument conditions will log PIC
because he is the sole manipulator of the controls and I will log PIC
because prior to the flight I was designated as the PIC and the safety
pilot. I can only log PIC if I'm properly rated for the aircraft that we
are flying.
2) What are the requirements for complex and high performance
aircraft? I thought that an endorsement was required for planes with
retractable gear and a adjustable prop and another for planes with a
greater than 200 horsepower engine. In my log book I see an
endorsement line for the HP (there isn't a FAR reference though) but
not for the complex. I looked up "complex" in the FAR and could not
find anything regarding this.
61.31(e) and (f). Thanks for helping me find this. I think the Index
should point to these for "Complex" and "High Performance". I have the
ASA 2003 FAR/AIM and couldn't find it right off the bat.
3) Ok, now the combination of the two. Lets say I do need an
endorsment for the complex/HP aircraft. Can I log time as the safety
pilot in this plane if I haven't yet gotten the endorsment for
complex/HP? 91.109.b.2 says the safety pilot just needs to be a
private pilot with the appropriate category and class ratings.
This is kind of answered in the first question but to clear it up I can
log the time as safety pilot as long as I meet the category and class
requirements. To log PIC in a complex or high perfomance aircraft I must
be properly rated. Otherwise I would be considered SIC.
Old August 8th 03, 03:03 AM
Ron Rosenfeld
On Thu, 7 Aug 2003 16:43:09 -0700, "JerryK"
Of course you can. There is no requirement to be current. 91.109 says
"rated". In addition 61.55(d) specifically exempts safety pilots from the
requirements of 61.55.
You do need a current medical, though.
Old August 8th 03, 03:10 AM
Ron Rosenfeld
I think you understand it but the use of "rated" in this context is
confusing the issue, since that term is used in 91.109 in a different way
than you appear to be using it.
Rated in this context just refers to category and class (i.e. aircraft,
single-engine land).
To log PIC as a safety pilot, in addition to being "rated", you must also
be current, have the proper endorsements and so forth. In addition, if the
pilot flying is also qualified to act as PIC, you must have made an
agreement with him that YOU would be the PIC. According to FAA legal
opinion, this agreement should be made prior to the flight.
Old August 8th 03, 03:38 AM
BTIZ
is an endorsement for High Performance, without reference to certain FAR
paragraph a valid endorsement?
There are a variety of different endorsements, two of which you seem
concerned:
FAR61.31(e), Complex, defined as Retractable Gear, Flaps and Controllable
Pitch Propeller (example, Piper Arrow 200HP, Beech Sundowner 200HP,
retractable Cessna Skylane 235HP (also requires High Performance)) or a
Seaplane without the retractable gear but has controllable pitch prop and
flaps
FAR61.31(f), High Performance, Engine with MORE THAN 200HP (example, Beech
Bonanza 285HP, Fixed Gear Skylane 235HP) all of which normally have retract
gear, prop and flaps
Also there is:
FAR61.31(g), Pressurized Aircraft at High Altitudes
FAR61.31(i), Tail Wheel aircraft
FAR61.31(j), Glider, for different launch methods
BT
"FryGuy" wrote in message
1...
I have a couple of questions that are unclear to me regarding being a
snip
2) What are the requirements for complex and high performance aircraft? I
thought that an endorsement was required for planes with retractable gear
and a adjustable prop and another for planes with a greater than 200
horsepower engine. In my log book I see an endorsement line for the HP
(there isn't a FAR reference though) but not for the complex. I looked up
"complex" in the FAR and could not find anything regarding this.
3) Ok, now the combination of the two. Lets say I do need an endorsment
for the complex/HP aircraft. Can I log time as the safety pilot in this
plane if I haven't yet gotten the endorsment for complex/HP? 91.109.b.2
says the safety pilot just needs to be a private pilot with the
appropriate
Old August 8th 03, 09:45 AM
Roger Halstead
On Thu, 7 Aug 2003 22:01:22 GMT, Andrew Koenig wrote:
Unless you hold an instructor or ATP certificate, you can only
log PIC time for the period during which you are the sole
manipulator of the controls.
Robert Not true... if more than one pilot is required (pilot and safety
Robert pilot) either one may be the PIC and log PIC.
Hmmm... other posters differ from you on that.
I think you're right -- you need separate endorsements for each
kind of high-performance airplane.
Robert Not true, an endorsement in a Cessna 210 is good for a Bonanza.
That's because a Cessna 210 is both kinds at once, so if you're endorsed
for a 210, you effectively have both endorsements.
On the other hand, if you're endorsed for a Cessna 177RG, I don't
think that endorsement is valid for a 182.
The 177 has less than 200 HP?
If it does then the 182 might not be valid for the 177 RG.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
Old August 8th 03, 11:50 AM
Ron Rosenfeld
On Thu, 07 Aug 2003 21:10:41 -0400, Ron Rosenfeld
That should be "airplane, ..."
Old August 8th 03, 03:03 PM
Robert Moore
Andrew Koenig wrote
You're certainly right when you're talking about yourself
because you have CFI and ATP certificates. But I still remember
reading somewhere, probably in AOPA Pilot, that for rest of us
mere mortals, only the sole manipulator of the controls can log
PIC.
Wrong! Wrong! Wrong!
From a Western Region FAA web site:
A private or commercial pilot may log PIC time when "acting as
pilot-in-command of an aircraft on which more than one pilot is
required under the - - - - regulations under which the flight is
conducted". [61.51 (e)(1)(ii)]
Normally, a safety pilot, required by regulations, who scans for
traffic for a pilot flying under simulated instrument conditions is
not pilot-in-command and thus logs second-in-command. However, if
the two pilots agree that the safety pilot is designated pilot-in-
command, the safety pilot/pilot-in-command may log PIC since he is
the pilot responsible for the operation and safety of the aircraft.
The pilot flying is "sole manipulator of the controls for which the
pilot is rated"" and may also log PIC. Therefore, two private
pilots may log PIC under these conditions. However, the safety
pilot/pilot-in-command must realize that anything that occurs
during the flight is his responsibility. Airspace violations, non-
compliance with ATC instructions, near mid air collision, and
runway incursions on the ground are all now charged to the safety
pilot. A recent article in a monthly aviation publications
discussed a flight where there was a violation and the two pilots
disagreed who was pilot-in-command.
Everyone in this thread would do well to check this web site.
http://www.awp.faa.gov/new/fsdo/art_pilot.htm
Bob Moore
Pilot Error? Is it Mr. Damron? Badwater Bill Home Built 3 June 23rd 04 05:05 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
AF investigators cite pilot error in fighter crash Otis Willie Military Aviation 0 January 9th 04 10:55 PM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 06:39 AM
