Blue Angels and Thunderbirds
Old October 20th 03, 02:38 AM
Big John
Nathon
Navy painted their birds dark blue on the top so they would blend in
with the ocean and light blue on the bottom so they would blend in
with the sky. They also painted their birds and accepted the hundreds
of pounds of weight penalty, to help prevent corrosion from the salt
air. The Navy F2H3 (Banshee) I flew in 1955 was painted all gray. Not
sure when they changed their paint schemes over the years.
The Air Force ended up not painting most of their aircraft and took
the several hundred pounds of weight savings. They did paint some when
corrosion was a factor as I recall.
The stealth birds they fly at night, F-117, B-2 are painted black (of
course G
Any 'old' Navy types who remember when the Navy changed their paint
schemes?
Big John
On Mon, 20 Oct 2003 00:45:32 GMT, Nathan Gilliatt
In article HqDkb.54323$La.52035@fed1read02,
"BTIZ" wrote:
BTW: I saw the F-117A, but did anyone see the B-2? I didn't think it was
that stealthy.
well.. stealthy is not how easy it is to "see" with your Mark-I eyeball...
but painted black for night flying does help..
The STEALTH is how it looks on RADAR.. what type of radar return it
REFLECTS..
Black paint is for nighttime low observable (LO) qualities--visual
stealth. Seems to be a significant mission requirement for lots of
military aircraft. I initially was going to say "these days," but WW2
airplanes were sky blue on the bottom sometimes, weren't they?
I don't recall the details, but I think I saw someone actually trying
the active camouflage that Dale Brown (Day of the Cheetah?) put it a
book years ago. The aircraft essentially shows you a picture of what's
on the other side, making it disappear.
- Nathan
Old October 20th 03, 02:47 AM
Hilton
Hilton wrote:
And, the highlight of the show, was a Stearman on steroids; i.e. with a
jet!
Each time he needed a boost, he fired that jet - it's amazing to see a
bi-plane literally rocketting up. Even stranger when there is some guy
standing on the wing! I don't think I'll ever be able to watch non-jet
aerobatics again.
Allow myself to correct... myself:
"In 1996, Jimmy Franklin debuted his latest project, the world's only
Jet-powered Waco biplane and will perform this year showing the Salinas
Valley residents what a customized aircraft can do! With the help of Les
Shockley (creator of the "Shockwave" jet truck.hey, his son is at the show
too.) they modified Jimmy's 1940 Waco with a T-38 (J-85) jet engine along
with a 450 horse power Pratt & Whitney radical prop engine, toss in 4500
pounds of thrust and over 2000 horse power and combined, it equals a
performance no one has ever seen or even attempted in this type of plane
before."
Hilton
Old October 20th 03, 02:49 AM
G.R. Patterson III
Paint jobs were an art form during that period. The Germans actually came up
with a paint that was durable but could be wiped off easily if the aircraft was
transferred to an area that required a different paint job. Flat black or dark
brown was used for night fighters. The British used a glaring medium blue for
high altitude aircraft; it was startlingly vivid at low altitudes but the planes
disappeared at 40,000' or more.
Allied aircraft used in the desert were painted a pinkish color that blended in
with the North African sand. There is or was recently a P-40 on the warbird
circuit painted this way. It caused quite a stir. The Germans used a very light
tan for the same reason, usually with a grey underside and splotches of brown on
the top surfaces. I once saw a photo of Joachim Marseille flying a 109 over
Tunisia taken from above. You could see two crosses and barely make out the
cockpit; the rest disappeared in the scrub.
You are likely thinking of the standard U.S. Navy paint job, which at one time
used sky blue for the underside of the planes.
National Geographic had a recent article that stated that suits for ground
forces are being tested that accomplish this. They're basically made of fiber
optic threads. The ends of the threads are carefully placed to conduct light
from one side of the suit to the other, making the soldier nearly disappear.
They aren't good enough for issue yet, it seems.
George Patterson
To a pilot, altitude is like money - it is possible that having too much
could prove embarassing, but having too little is always fatal.
Old October 20th 03, 04:23 AM
Jeff Franks
that stealthy.
But you have to admit. Seeing that B-2 fly is freaking WIERD! Even more so
than the first time you saw a Harrier do a performance, which is getting old
now (Can't believe I just said that
The B-2 just doesn't look like something that should fly.
Old October 20th 03, 05:06 AM
BTIZ
"Bob Martin" wrote in message
was
that stealthy.
Hilton
eyeball...
REFLECTS..
I may be wrong, but I think he was trying to make a bit of a joke...
you could be right...
Old October 21st 03, 12:12 AM
John Galban
"Hilton" wrote in message ink.net...
snip
with a 450 horse power Pratt & Whitney radical prop engine...
With a J-85 in the back, there's nothing radical about the P&W :-)
Old October 21st 03, 12:18 AM
John Galban
"G.R. Patterson III" wrote in message ...
I've seen one of these in action. They're pretty darned good. In
the open, you can see a blurry human shaped outline of the suit. With
some cover, I imagine the wearer would just disappear.
Old October 21st 03, 12:26 AM
John Galban
"Hilton" wrote in message link.net...
that stealthy.
G Back in the days before the F-117 was allowed to do static
displays at AFB Open Houses, the local Air Force bases would rope off
a large section of ramp and hang a sign on the rope that said "F-117A
Stealth Fighter". They would also include 3 sets of chocks where the
wheels were supposed to be. I was amazed at how many people fell for
it.
Old October 21st 03, 06:23 AM
Bob Fry
"Hilton" writes:
And, the highlight of the show, was a Stearman on steroids; i.e. with a jet!
The same guy was at Oshkosh (not a Stearman btw). What's really weird
is the sound: jet engine noise, but still with propeller racket.
Really shows the difference between engine and prop noise.
Old October 21st 03, 02:44 PM
Jay Honeck
I had the privilege of seeing the B-2 from *above*, flying out of Oshkosh a
couple of years ago. He was coming in for a low pass, and I was departing
to the south.
It looks even stranger from that angle, hard as that is to imagine.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Frequencies for Thunderbirds and Blue Angels William W. Plummer General Aviation 0 August 14th 04 12:10 AM
