Manual
Old January 17th 12, 09:40 PM posted to rec.aviation.soaring
bish
Default Manual
Hi
I have to bring the owner manual when I fly my LS 6.
I have a copy on a memory key. Is it acceptable?
Regards
S6
Old January 17th 12, 09:56 PM posted to rec.aviation.soaring
jcarlyle
Default Manual
On Jan 17, 4:40 pm, bish wrote:
Hi
Regards
S6
I don't know for certain, but I'd guess that the FAA would say if you
can't read it on the spot, anywhere, anytime, it isn't acceptable. I
printed my LS8 manual out double sided with 4 pages on each surface of
a 8.5 by 11 sheet, and I carry that. It's a bit small, but very
readable. I also carry a PDF copy of the manual on my iPhone. Good
luck!
-John
Old January 18th 12, 12:05 AM posted to rec.aviation.soaring
kirk.stant
Default Manual
Hi
I have a copy on a memory key. Is it *acceptable?
Regards
S6
luck!
-John
I took my manual to a Kinkos and had them reduce copy it at about 1/4
size, then laminated the front and back covers, and spiral bound the
little thing. Now small enough to stick anywhere in the cockpit, and
still fully usable.
It's lasted over 10 years stuck in the pouch that comes with the
LS6...
Kirk
66
Old January 18th 12, 12:25 AM posted to rec.aviation.soaring
lanebush
Default Manual
Hi
Regards
S6
luck!
-John
little thing. *Now small enough to stick anywhere in the cockpit, and
still fully usable.
LS6...
Kirk
66
You know that in the US the manual is not required to be on board if
the limitations are properly marked via placards and decals.
XF
Old January 18th 12, 02:44 AM posted to rec.aviation.soaring
Dan Marotta
Default Manual
I don't think I ever carried the manual in my LS-6, but I know that it would
easily slip behind the seat. Seriously, if you need to be reading the
manual in flight, you shouldn't be flying...
"lanebush" wrote in message
On Jan 17, 7:05 pm, "kirk.stant" wrote:
Hi
Regards
S6
luck!
-John
still fully usable.
LS6...
Kirk
66
XF
Old January 19th 12, 07:33 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
Default Manual
On Tue, 17 Jan 2012 19:44:06 -0700, "Dan Marotta"
I can just see the NTSB report: "Cause of accident: pages 49 & 50 of
the POH stuck together"...
rj
Old January 18th 12, 02:48 AM posted to rec.aviation.soaring
T[_2_]
Default Manual
XF
That's news to me! Last I read, if it was listed in the TCDS or if the
manual (POH) said it had to be in the glider, then it needs to be in
the glider regardless of what is placarded. And the POH specifies the
minimum placards.
T
Old January 18th 12, 02:55 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Manual
XF
minimum placards.
I've been flying gliders in the US since 1976, and I don't recall having
the manual on board ever being a safety or enforcement issue. Does
anyone know of an incident involving having a manual on board?
email me)
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
G 103 Manual Charlie Papa Soaring 2 June 8th 09 10:12 AM
FA: B-737 OPERATIONS MANUAL - Ops Manual for a B-737 Jet Peter Aviation Marketplace 0 December 28th 04 01:08 AM
Manual PA-46 Gerard Ververs Instrument Flight Rules 0 November 23rd 04 07:50 PM
Manual PA-46 Gerard Ververs Products 0 November 22nd 04 10:41 PM
LX1000 Manual & Speed Astir Manual Avron Tal Soaring 1 June 20th 04 07:15 AM
