New Ventus 2 and Discus Winglets - M&H
Old February 21st 12, 03:41 PM posted to rec.aviation.soaring
Dan Marotta
Default New Ventus 2 and Discus Winglets - M&H
Wonderful! Great stories and good information.
"Peter Purdie" wrote in message
.com...
I can personally verify that Harold Drew, scrutineering at the '65
UK Worlds measured the Standard Class gliders by opening two
hangar doors to marginally over an accurate 15,000mm and
required each glider to be manoeuvred through with wings level.
He made the same reply ('you can fly through the gap of you
prefer') when offered the same excuse.
The Finnish Vasama was significantly over span; the Team
Manager offered the explanation that the glider was so new the
wooden spars were still growing. Firm action with a plane to the
wingtip fairings made it legal, if a little less pretty.
At 20:28 20 February 2012, Chris Nicholas wrote:
Re canted winglets increasing span: I recall a reported
conversation
between a well-known competition pilot (WKCP) and purveyor
of
modifications etc., and a competition official (CO), re some
new wing
tips.
CO: It exceeds 15m span now.
WKCP: Not when it=92s flying =96 the added dihedral from the
wings flexing
reduces it to 15m.
CO: When you show me by flying between two posts 15m
apart without
hitting them, I will let you compete with those.
End of conversation.
Chris N.
Old February 21st 12, 04:41 PM posted to rec.aviation.soaring
Derek Mackie
The FAI Class rules are clear that the measurement is in the
"unloaded" condition, which is taken to mean that water, wing mass,
gravity and lift are all negated. That condition can be subjective,
but they give the example in the rule that it normally means that the
measurement is taken with the wing supported so that the trailing edge
is straight.
Ventus C Masak Winglets hans Soaring 6 August 25th 06 08:11 AM
Ventus Winglets Shawn Knickerbocker Soaring 2 August 24th 06 11:24 PM
Discus Winglets Peter F Soaring 8 December 12th 05 04:29 AM
Discus Winglets Kevin Neave Soaring 2 October 15th 03 11:35 AM
Wanted: Ventus C Winglets E.Mertins Soaring 1 October 14th 03 01:15 PM
