Thanks, Guys. For reasons I don't need to discuss here, I was out of the
sport for nine years. A lot changed during that time and I'm still catching up... "Marc" wrote in message ... On Mar 10, 10:52 am, fredblair wrote: My question had nothing to do with 'cheating'. I am an Instructor and I will be responsible for teaching members how to properly use these new devices to obtain their badges. My question was just a question of fact: if the GPS altitude shown in the IGC file is going to be accepted as the altitude of the flight, then why do we worry about pressure altitude? I thought the whole idea of approving the 'position recorders' was to eliminate the need for the more expensive units that include a calibrated pressure sensor. A couple of posts after this, makes a statement that we will still need pressure altitude, since that is what is in Sporting Code 3. Isn't the new Sporting Code going to be re-written to eliminate the pressure altitude requirement. The Sporting Code currently in effect through September 30, 2012 still requires that pressure altitude evidence be provided along with GPS- derived position data for Silver and Gold badges. If a badge flight is to be flown using a local NAC approved "position recorder" which does not record pressure altitude, then a barograph must also be carried, and both the GPS flight data and the barograph trace must be submitted for any badge legs. As of October 1, 2012, IGC flight data from an approved position recorder containing GPS position data and GPS altitude will be all that is required for these badge legs, no more barograph. Again, due to concerns that during a normal summer soaring day a gain of height measured by pressure altitude requires climbing to a higher actual elevation, than the (more accurate) GPS altitude measurement, an extra margin was added in an effort to equalize things. So, as of October 1, a climb to 1100M (as measured by GPS) will suffice for claiming Silver altitude using a GPS-only position recorder, no need to worry about pressure altitude. 1000M (as measured by pressure altitude) will continue to be acceptable when using an approved flight recorder, a position recorder which records pressure altitude, or a position record and barograph. I know this is a bit confusing, but believe me, getting Silver and Gold badges will be easier and cheaper from October on... Marc |
On Mar 9, 8:54*pm, fredblair wrote:
On Mar 8, 2:05*pm, urosp wrote: My strong belief is that most pilots fly for fun and because of that they do not need fully certified flight recorders (where the price is at least 5 times higher). They would either like to improve their flying, share flights with other pilots, attend on-line competitions or simply record their flights. But from the beginning I have received several suggestions that device could be also certified as position recorder with NAC (National Air Sport Control). Several people helped me and now flyWithCE Flight Recorders are certified by NAC in Australia, Canada, Slovenia, United Kingdom and United States. The device could be then used as position recorder for Silver and Gold FAI badges. On 2nd and 3rd of March there was and IGC Plenary Meeting in South Africa where they decided that for Silver and Gold badges you do not need extra altitude recorder and that GPS altitude will be accepted. The difference with fully certified flight recorders is that pilot should account 100 meter altitude margin for possible GPS altitude error (for instance 1100 meter gain of height for Silver badge). The new rule will be applied when updated Sporting Code will be published. If you wild like to know more about flyWithCE Flight Recorder and flyWithCE Logbook software (which ships together with the device) please visithttp://www.flywithce.com. Best regards Uros Podlogarwww.flywithce.com Any idea when the Sporting Code will be printed, so that we can start, officially using the Position Recorders? Another question, in the above post, it says that you might want to use an 1,100 meter gain for the Silver Badge to make sure for GPS errors; how is the SSA Badge Dude going to know what the "real" altitude is, if the only reported data will be the GPS altitude?? Updates to Sporting Code Section 3 are normally released on October 1. You must gain 1100 meters as measured by the GPS, rather than the 1000 meters that would be acceptable using pressure altitude. The extra margin is intended to increase the likelihood that the "geopotential" altitude gain (as measured by GPS) will exceed the pressure altitude gain required by the Sporting Code... Marc |
flyWithCE tip #2: flyWithCE Flight Recorder and OLC | urosp | Soaring | 0 | February 16th 11 05:28 PM |
flyWithCE tip #1: How can you view flights in flyWithCE Logbook? | urosp | Soaring | 0 | February 11th 11 06:39 AM |
flyWithCE Flight Recorder | John Godfrey (QT)[_2_] | Soaring | 4 | November 13th 09 07:10 PM |
FlyWithCe recorder woes | Ferstlesque | Soaring | 3 | June 29th 09 06:23 AM |
New flight recorder - flyWithCE Flight Recorder | uros | Soaring | 12 | May 5th 09 08:31 PM |
