Interesting optical effect
Old November 9th 03, 01:07 PM
Mark Mallory
Maule Driver wrote:
Actually I see it on the ground but it is diffuse and unfocused - like a
very strong headlight shining on a very distant area. You just get a
diffuse bright spot.
I think I get Peter's concept and understand it but can't quite get it to
'intuit'. But makes some sense. Can't quite understand why the area on the
ground where sunlight would reflect back at 180deg (or normal to the average
surface) would be so much brighter than points where the sunlight would
reflect back at say 45 deg to the avg surface. Doesn't make sense when I
think of a forest of trees, but it is quite clear when same light refects of
a truck on a highway. So I kind of get it. Thanks Peter and Robert.
Peter didn't really explain it. Except for specially-designed surfaces that
incorporate corner reflectors (like taillights, or bicycle reflectors), a
randomly-oriented surface doesn't preferentially reflect light back in the
direction of it's source. However, the effect has a very simple explanation:
The bright spot is simply the result of the absence of SHADOWS cast by objects
on the ground. On a sunny day, EVERY object on the ground - rocks, blades of
grass, trees, people - casts a SHADOW. When one looks at the ground from a
considerable distance, each tiny object and it's *shadow* are all averaged
together to contribute to the total brightness of the surface. However, when
one looks at the ground from the direction of the Sun, every shadow DISAPPEARS
behind the object that casts it! As a result, in that ONE direction there are
NO SHADOWS to dilute the intensity of the light reflected back to the observer;
the result is a *bright spot* in which the apparent reflectance is very nearly
DOUBLE that in any other direction.
The effect is not noticed if you are standing on the ground (or very near the
ground in an airplane) because your OWN shadow blocks the sunlight in that
direction. When the airplane climbs to a considerable height (such that it
appears much smaller than the Sun as seen from the ground) the shadow of the
airplane ceases to exist and no longer blocks the light in the "anti-sun"
direction, allowing the effect to be seen.
Old November 5th 03, 02:38 AM
Jay Beckman
"Kobra" wrote in message
This may be something different, but I saw this flying to Lake George two
weeks ago. I was about 1000' above the deck with the Sun high above me.
My
frontseat passenger keep saying a circular rainbow was following us and
that
the plane's shadow was in the middle of it. She took a picture of it that
I
thought would never show up. But it did. I have to get her to scan it.
I told a friend of mine about it and he said that effect has a name. He
found it on the web and sent me this link:
http://www.touchingthelight.co.uk/features/brocken.htm
Low and behold...that is what we saw.
Kobra
FWIW...
If you want to bounce a target from directly out of the sun, place the
sunball squarely on your intended target.
Old November 5th 03, 02:46 AM
Teacherjh
I know what each of these words means, but when put together in this manner I
can't make head or tail out of it.
Jose
Old November 5th 03, 04:39 AM
G.R. Patterson III
Translation - If you're flying a fighter and wish to attack another aircraft
while keeping the sun directly behind you so he can't see you, then maneuver
your plane until that sunball hits his plane and dive straight at him.
George Patterson
If you're not part of the solution, you can make a lot of money prolonging
the problem.
Old November 5th 03, 04:38 PM
Maule Driver
That makes sense!
"G.R. Patterson III"
aircraft
maneuver
Old November 5th 03, 09:49 AM
JamesB
weeks ago. I was about 1000' above the deck with the Sun high above me. My
frontseat passenger keep saying a circular rainbow was following us and that
the plane's shadow was in the middle of it. She took a picture of it that I
Kobra
See the book "Chasing the Glory" by Michael Parfit. A very good read by
a
small plane pilot flying around the US. The 'Glory' is that which you
saw on the cloud/haze layer.
JamesB
To email me get the lead out
Old November 5th 03, 03:04 PM
C J Campbell
The rainbow is a perfect circle centered around the observer. The rainbow
that you see will be slightly different from a rainbow seen by a person
standing right next to you. If you move, the rainbow will always move with
you. The shadow of the observer is always in the exact center of the
rainbow.
Old November 5th 03, 03:01 PM
C J Campbell
Last night I was flying about sunset and the sun cast a perfect reflection
of itself on a thin cloud just above it on the horizon. We had two suns to
look at for about half an hour.
The Meredith Effect Corky Scott Home Built 19 September 4th 04 04:01 PM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 05:09 AM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 05:11 AM
Great Lakes lake effect snow Paul Tomblin Instrument Flight Rules 30 October 21st 03 05:15 PM
