vincent p. norris wrote: Not if you maintain positive G all the way around (as in aileron roll). You don't have positive G all the way around in an aileron roll. To maintain positive G, you need a barrel roll. vince norris You are thinking slow roll -- you DO maintain positive G in an aileron roll. |
vincent p. norris wrote: Not if you maintain positive G all the way around (as in aileron roll). You don't have positive G all the way around in an aileron roll. In a properly done aileron roll you certainly do... To maintain positive G, you need a barrel roll. Or an aileron roll. Were you thinking of a slow roll? Hamish |
Lets kill this thread right now.
1. A 'barrel roll' is a roll where (if done properly) you as a passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, it feels like straight and level flight. Starting nose position and of course air speed varies between underpoweed GA aircraft and super sonic Fghters. 2. A 'slow roll' (point roll) is done with the nose pointing at a single point (normally picked out o horizon) all the way around. In Fighters, can be done from straigaht and level flight. Most GA aircraft require a little airspeed above cruise. To do you raise the nose above the point on the horizion and start a roll with aileron. As you continue the roll you feed in top rudder to hold nose up and adjust the elevator to keep nose on the point. As roll continues you feed in down elevator (here's your negative G's) to hold the nose up and on the point while relaxing the top rudder input. As roll continues you again feed in top rudder (opposite rudder) to hold nose up on point and take off down elevator holding nose on point. After passing the 270 degree position, you start removing top rudder and adjust the elevator to keep nose on point. As you come back out straight and level all controls are again in neutral. Negatiave "G's" are of course pulled when on your back. Roll can be relatitivly slow or rapid as long as nose can be held on a point going around. 3. An aileron roll is just laying the aileron over (normally full aileron) and letting bird roll. Depending on type of aircraft (fighter or GA) the nose makes a circle around a point. Fighters can do at cruise with little or no nose above the horizon. GA requires a start with the nose above the horizon due to slower rate of roll and bird ending up nose low because no other control input to hold nose up while inverted is used There are also a few fine points the experts use that I have not covered but above are the basics. Been there done that for longer (65 years) than BOb has been flying. ![]() Big John. On 4 Nov 2003 12:06:03 -0800, (Scott Lowrey) wrote: If I'm crusing along at 100 KIAS in a 172 in clear air and I roll left while maintaining neutral rudder, what will happen if I don't neutralize the ailerons? I'm picturing the plane rolling on to its back while losing altitude and either completing the roll (doubtful) or stalling into a dive and recovering in the other direction , right side up. (BTW, that's a split-S, isn't it?) ----clip---- |
Big John wrote
1. A 'barrel roll' is a roll where (if done properly) you as a passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, it feels like straight and level flight. Starting nose position and of course air speed varies between underpoweed GA aircraft and super sonic Fghters. Hey John, I didn't make-up that post, it came straight from: http://acro.harvard.edu The Barrel Roll is a not competition maneuver. The barrel roll is a combination between a loop and a roll. You complete one loop while completing one roll at the same time. The flight path during a barrel roll has the shape of a horizontal cork screw. Imagine a big barrel, with the airplanes wheels rolling along the inside of the barrel in a cork screw path. During a barrel roll, the pilot experiences always positive G's. The maximum is about 2.5 to 3 G, the minimum about 0.5 G. Care to give us a reference for your definition? Bob |
Robert
You talk about doing a LOOP in association with a roll. A LOOP has no roll in it.The ailerons are only used to keep the wings 90 degrees to the plane of the loop. A IMMELMAN or CUBAN EIGHT has a roll associated with part of a loop. The description of making a corkscrew inside a tube is another way of defining the flight of the airplane when it does a BARREL ROLL. In my prior post I said to pull one 'G' when I should have said two 'G'. Same 'G' as pulled in a one 'G' turn (one gravity 'G' and one acceleration 'G'). Not sure you would or would not call a barrel roll a compition maneuver. Never flew in compiton. In the airshows we used to put on didn't do BARREL ROLLS becaue they were not very spectular from the ground nor percicsion manuevers.. In airshows many times we would do a 8 point SLOW ROLL stoppmg momentarily every 45 degrees of roll. This is a precison maneuver and takes a lot of practice with elevator, rudder and aileron in coordination to do correctly and with precision so looks good from ground. Seen in compition today. My reference is years and years of doing acrobatics and teaching same in both conventional aircraft and jets. As a matter of interest, most of the victory rolls you see of Fighters returning from a combat mission with kills are aileron rolls. You could see some (rare) put a little forward stick in when inverted but had to look close. Some birds didn't do good aileron rolls (P-51 for instanace) If you did an aileron roll on the deck you normally bumped the stick upside down to keep the nose up. The P-40 however aileron rolled like a spool on a thread. Big John On Sun, 09 Nov 2003 03:55:51 GMT, Robert Moore wrote: Big John wrote 1. A 'barrel roll' is a roll where (if done properly) you as a passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, it feels like straight and level flight. Starting nose position and of course air speed varies between underpoweed GA aircraft and super sonic Fghters. Hey John, I didn't make-up that post, it came straight from: http://acro.harvard.edu The Barrel Roll is a not competition maneuver. The barrel roll is a combination between a loop and a roll. You complete one loop while completing one roll at the same time. The flight path during a barrel roll has the shape of a horizontal cork screw. Imagine a big barrel, with the airplanes wheels rolling along the inside of the barrel in a cork screw path. During a barrel roll, the pilot experiences always positive G's. The maximum is about 2.5 to 3 G, the minimum about 0.5 G. Care to give us a reference for your definition? Bob |
Big John wrote
You talk about doing a LOOP in association with a roll. No John, I didn't talk or write about...... I just quoted from the acro.harvard.edu web site and William Kershner's fine book. You may not have seen the picture from the Kershner book when you wrote this, but write back when you have seen the barrel roll as described by someone who is considered an authority in the field. My reference is years and years of doing acrobatics and teaching same in both conventional aircraft and jets. Still waiting for reference documentation. :-) Bob |
Robert Moore wrote: No John, I didn't talk or write about...... I just quoted from the acro.harvard.edu web site and William Kershner's fine book. You may not have seen the picture from the Kershner book when you wrote this, but write back when you have seen the barrel roll as described by someone who is considered an authority in the field. I've been shown two different ways to do a barrel roll. The first was to pick a reference off one wingtip. Start pulling and rolling toward the reference point. Once inverted you would be 90 degrees off original heading (pointed at the ref point). You continue to roll and pull returning to the original heading. The second way was to pick a reference point over the nose. Put the nose slightly to one side of that point then roll and pull keeping the nose the same distance from the reference point. The first is the big loopy typy barrel roll - and a lot of fun to do. The second is a much tighter roll without any loop. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Big John wrote
My reference is years and years of doing acrobatics and teaching same in both conventional aircraft and jets. Check-out Mr. William Kershner at: http://www.kershnerflightmanuals.com/ Bob |
Bob
Read Kershner's life story. Note that he left Moffett and crapped out of the Navy the year I arrived at Moffett to fly All Weather Jet Fighters (VF-23). The Navy was just transitioning from Prop Fighters (F4U like he flew in West Pac, etc) and one of my tasks was to give them the experience of Air Force Jet Fighter operations including energy management which was very important in those first generation jet fighters.. Reading his description of life events it seems he pushes the envelope some like Zzzzom. I see nothing he has done to warrant your placing so high on a pedestal. He gives credit to only one document where he lifted some data/technique. I also detect the wording of other manuals I have seen through the years that he didn't give credit to. Of course it may be just how many ways you can say loop? He says he flies one or two students a month.That's not enough to maintain proficiency or write from a current background. You keep asking for my credentials. What do you want, my Military Form 5 where every flight I make in 28+ years is listed. There is at least one or more pages per month depending on activity and totals well over 350 pages and about 2 1/2 - 3 inches thick weighing 3-4 pounds. Or my formal education of BS with work on a MS. Or the Patent number of my patents? I'm married and have four grown daughters with three grand children and three great grand children. I'm over 21 and legal to buy 'booze' so drink Vodka on the rocks. My GA Flight Logs are pretty thin as I didn't log a lot of the time because I wasn't trying to build to any number of hours since I had over 6500 in heavy iron. It looks like there are several different ideas about acrobatic flyng on this thread. I've expounded on mine so others can list their way and I'll set back and might learn somethng??? One is never too old to learn it is said. I don't suffer fools but can be moved by facts. Fly safe and keep the ball in the center unless you are slipping the excess altitude off on final or landing in a cross wind. Big John On Sun, 09 Nov 2003 23:12:40 GMT, Robert Moore wrote: Big John wrote My reference is years and years of doing acrobatics and teaching same in both conventional aircraft and jets. Check-out Mr. William Kershner at: http://www.kershnerflightmanuals.com/ Bob |
Big John wrote:
Robert You talk about doing a LOOP in association with a roll. A LOOP has no roll in it.The ailerons are only used to keep the wings 90 degrees to the plane of the loop. A IMMELMAN or CUBAN EIGHT has a roll associated with part of a loop. The description of making a corkscrew inside a tube is another way of defining the flight of the airplane when it does a BARREL ROLL. As a lurker here who has never and will never do a single loop or roll, it seems to me you two are both describing exactly the same maneuver but using slightly different words. Both you and Bob agree that the barrel roll consists of having the airplane follow a corkscrew path as if it were following the inside wall of an imaginary barrel, or tube, in the sky. If the plane were to roll while going straight down the long axis of the tube it would be an ordinary "slow" roll. OTOH, if the plane were flying along the inside circumference (i.e. at 90 degrees to the long axis) of the tube it would be doing loops. The corkscrew path of a barrel roll is halfway between these two situations (i.e. at about a 45 degree angle to the long axis of the tube), so it doesn't seem unreasonable to describe it as the combination of a loop and a roll. |
??Build rolling tool chest? | Michael Horowitz | Owning | 15 | January 27th 05 04:56 AM |
Rolling Thunder | Mortimer Schnerd, RN | Military Aviation | 10 | June 14th 04 12:49 AM |
B-52 crew blamed for friendly fire death | Paul Hirose | Military Aviation | 0 | March 16th 04 12:49 AM |
Defensive circle | Dave Eadsforth | Military Aviation | 23 | October 9th 03 06:13 PM |
Talk about runway incursions... | Dave Russell | Piloting | 7 | August 13th 03 02:09 AM |
