On Friday, March 23, 2012 10:17:30 AM UTC-5, bumper wrote:
On Mar 23, 7:30*am, wrote: On Friday, March 23, 2012 8:53:21 AM UTC-5, T8 wrote: The powerflarm alarm would sound and a second or two later the near miss would occur. The range was unacceptably poor... Don (DK) Don, Were you using the "optional" small panel antenna? This is the flat black, about 1" X 4" receive antenna that should be mounted vertically and a couple of feet away from the PowerFlarm. This is intended to increase the PF effective range and is included with the portable. thanks, bumper No. I was using the antennas mounted to the rear of the portable unit. It is not easy to find a spot a couple of feet away from the panel which will not have some kind of carbon fiber blockage of the antenna. Don |
On Mar 23, 9:06*am, wrote:
No. I was using the antennas mounted to the rear of the portable unit. It is not easy to find a spot a couple of feet away from the panel which will not have some kind of carbon fiber blockage of the antenna. Don I simply ran the wire for mine off to the left side of the glare shield, then back along the canopy frame and mounted the antenna on the Plexiglas just aft of the sliding window (ASH-26E) using a bit of Velcro. Should work reasonably well there I'd think, especially towards the front. bumper |
On Friday, March 23, 2012 11:20:41 AM UTC-5, Eric Greenwell wrote:
On 3/23/2012 7:30 AM, dfkroesch wrote: I had three near misses in thermals. The powerflarm alarm would sound and a second or two later the near miss would occur. The range was unacceptably poor... Was this due to poor range; i.e., PowerFlarm did not receive the signal from the other glider until it got too close to give a quicker warning? I would guess that if you are thermalling with another glider that might become a threat, that would be well within receiving range, and the short warning time was due to poor threat determination, rather than poor signal detection. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) My three "near misses" were thermal entering problems. Twice the other guy - once my fault. I am aware that the other guys might be keeping score in a different way..... From what I saw, the portable PowerFlarm range was clearly less than 1/4 mile - perhaps more like 1/8 mile. One or two seconds warning is not enough. Don |
FS - Powerflarm Portable | Westbender | Soaring | 0 | January 9th 12 09:21 PM |
PowerFLARM at Uvalde | Paul Remde | Soaring | 19 | August 1st 11 05:52 AM |
Results and reports from Seniors" | Walt Connelly | Soaring | 4 | April 4th 11 01:03 PM |
PowerFLARM | Paul Remde | Soaring | 9 | November 6th 10 04:30 AM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
