2-place Intercom and 4 Headsets
Old November 12th 03, 03:50 PM
Zeno
Hello community,
imagine you have a plane (rented) with a build in 2-place intercom
(sigtronics in this case) and want to give your passengers their own
headsets, so you can communicate with them. It is not necessary for them
to
hear the radio transmissions you make, although, it would be nice (if
legal
What do you need? An additional portable 2-place intercom? A Y-cable
extension?
Thanks in advance for your answers.
Regards
Kai Glaesner
I've tried to daisy chain two portable intercoms together when I had this
same situation. It resulted in nobody being able to hear or speak. I don't
know why this happened. Also had bad results combining a portable intercom
with a panel mount intercom in a 4 seat airplane only equipped with headset
jacks for the front seats.
Old November 12th 03, 04:29 PM
EDR
In article , Kai Glaesner
extension?
Plugging a second intercom into an existing intercom will result in
feedback if the mic plugs are plugged in. This is especially true if
you have the second intercom plugged into the pilots side mic jack. You
may not hear it within the airplane, but if you transmit, all anyone
will hear is a squeal.
Two Y-cords may work, or not , depending on the impedances of the
headsets.
Old November 12th 03, 04:33 PM
Ron Natalie
"EDR" wrote in message ...
extension?
Funny, it works just fine for me. Why would their be feedback. The intercom
looks like a headset to the the thing it's plugged into. The only real fun and
games is getting the PTT's and the squelches right if you intend to actually
use both intercoms. In my case I just plug everybody into the four place
and plug the portable into a single mic/headphone jack (just as if there was
not an intercom installed in the first place).
Old November 13th 03, 01:18 AM
Mike Weller
On Wed, 12 Nov 2003 11:33:06 -0500, "Ron Natalie"
That's what I do, too, with a sigtronics. I use a separate push to
talk switch, through the sigtronics, so that the other microphones are
disconnected when the pilot transmits. Works fine.
Mike Weller
Old November 13th 03, 08:14 AM
Thomas Borchert
Edr,
I wouldn't know why. Just plug the 4-place into the pilot side and
switch off the installed intercom.
Thomas Borchert (EDDH)
Old November 13th 03, 02:23 PM
EDR
In article , Thomas Borchert
Edr,
That is correct, and that is what I do.
However, the original poster asked about plugging a two place intercom
into an existing intercom so four could communicate.
Old November 13th 03, 05:17 PM
gross_arrow
EDR wrote in message ...
extension?
that's not my experience. i frequently fly a 6-place plane with a
4-place intercom. on the occassions when i put people in the back
two seats (like young eagles flights), i use _two_ 2-place portable
intercoms to expand the intercom to 6 place. they are even different
brands of portables, but i haven't had any problems with feedback,
and everyone seems to hear o.k. i do make it a point to use two
of the same model headset into each intercom. (i have 6 headsets --
2 lightspeeds, 2 peltors, and 2 pilot avionics cheapies.)
headsets.
y-chords is something i would stay away from. they halve the impedance
seen at the jack. depending upon the design of output stage design of the
intercom, this could present a problem. in addition, i'm pretty sure
it's impossible to "y" the mike side -- losses would be too great, so
you'd be left with "receive only" at at least one of each "y'd" position.
mho,
g_a
Old November 14th 03, 12:14 AM
Teacherjh
Actually, I found that an ordinary aircraft mike works well as an intercom
mike. You push to talk (it won't transmit if it's on the intercom side), and
pass the mike around as needed. A good solution for an occasional need.
Jose
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill Aviation Marketplace 0 December 11th 03 09:41 PM
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill Instrument Flight Rules 0 December 11th 03 09:41 PM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Aviation Marketplace 1 October 17th 03 02:04 AM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Aviation Marketplace 0 October 17th 03 01:25 AM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill General Aviation 0 September 4th 03 04:41 AM
