Flying w/faulty gas gauge
Old November 15th 03, 08:22 PM
Angus Davis
Yossarian wrote:
I understand that functional fuel gauges are required equipment for day VFR
flight.
Per the FARs, your gauges were functional. The only requirement is that
when the tanks are empty, the gauges read empty. If they show full when
the tanks are 1/4 full, that is not a problem in so far as the FARs are
concerned. Repeating, the only regulatory requirement is for gauges to
be accurate when the tanks are empty. That's why you should pay little
attention to them at all, and do your fuel calculations with diligence.
-angus
Old November 15th 03, 08:30 PM
Ron Natalie
"ArtP" wrote in message ...
Sooner or later we come to the point when the POH says switch to
the fullest tank.
You always know which one is fullest after you run one dry.
Old November 15th 03, 08:35 PM
Ron Natalie
"Angus Davis" wrote in message ...
flight.
Sorry, the FARs don't say that. The FARs don't say anything about accuracy.
The much misattributed FAR about them being empty just says that the E mark
means zero usable.
concerned.
91.205 says you must have operational guages. In this case the guage is NOT operating
the way it was designed. If the thing is really bouncing between 0 and Full on the ground
there is something seriously wrong. Not only is it hardly legal, I'd really question what
was going on.
Repeating, you are wrong.
Yeah and I have had two close friends who have put airplanes into off airport landings
because they decided not to look at the gauges. You should take the pessimistic
approach of always believing the gauges if they tell you that there is less fuel than
you predict by your preflight planning, but not if they tell you that there is more!
Old November 15th 03, 08:51 PM
Yossarian
91.205 For VFR flight during the day, the following instruments and
equipment are required:
(9) Fuel gauge indicating the quantity of fuel in each tank.
http://www.access.gpo.gov/nara/cfr/c...4cfr91_00.html
VFR
flight.
-angus
Old November 15th 03, 09:10 PM
Jim Weir
I have heard this repeated for quite a while, and I can't find the pertinent
section of the aircraft certification regs. Would you mind posting the chapter
and verse where I can find this requirement?
-when the tanks are empty, the gauges read empty. If they show full when
-the tanks are 1/4 full, that is not a problem in so far as the FARs are
-concerned.
http://www.rst-engr.com
Old November 15th 03, 09:21 PM
Tony Cox
m...
accuracy.
mark
means zero usable.
concerned.
NOT operating
Full on the ground
was going on.
Well, I'd certainly want to know why a gauge was flicking
around, but being pedantic (as I would be if called on it
by the FAA), how am I to know if my gauges are operational?
For that, I'd go to my POH for guidance. My POH tells me
that my fuel gauges should read 'red line' when there is no
fuel in the tank. It says nothing else. So I'd argue that I could
reasonably conclude my gauges were just fine if they showed
full when in actual fact they were only 1/4 full. And since
the FAR's insist I operate my plane consistently with the
POH & flight supplements, I'd claim regulatory backing for
this position.
Dr. Tony Cox
Citrus Controls Inc.
e-mail:
http://CitrusControls.com/
Old November 15th 03, 09:22 PM
Ron Natalie
"Jim Weir" wrote in message news
It doesn't say that. 23.1337 says the guage must be calibrated (but doesn't give any specific
accuracy). The part that people keep passing around by is the (1), but they ignore the fact
that it comes after "In Addition" . The empty pronouncement just says that the bottom mark
is supposed to be zero usable as opposed to bone dry:
(b) Fuel quantity indication. There must be a means to indicate to the flightcrew members the quantity of
usable fuel in each tank during flight. An indicator calibrated in appropriate units and clearly marked to
indicate those units must be used. In addition:
(1) Each fuel quantity indicator must be calibrated to read "zero" during level flight when the quantity of
fuel remaining in the tank is equal to the unusable fuel supply determined under § 23.959(a);
Old November 15th 03, 09:53 PM
mike regish
It's only requirement is that it reads empty when the tank is empty. Got a
watch? That's a hell of a lot better gas gage than that thing on the panel.
mike regish
"Yossarian" wrote in message
VFR
flight. Yesterday during my preflight in a 172 I saw that the right gauge
was functioning intermittently--it would show full, flicker down to zero,
bounce around, etc. Tank was visually confirmed full. Mechanic messed
around with it for a while to no effect.
Would you fly this airplane?
Old November 15th 03, 10:13 PM
Peter Duniho
"Tony Cox" wrote in message
nk.net...
Per the FAR, if they show the amount of fuel in the tank, they are
operational. If they don't, they aren't. It's not rocket science. If you
have gauges that show full tanks even when they are only 1/4 full, the
gauges are not in compliance with the relevant regulation.
Just because the POH only describes your "red line" for the zero fuel point,
that doesn't mean there aren't additional requirements for accuracy.
Pete
Old November 15th 03, 10:45 PM
mike regish
Two watches will do that. Or a double timer like I use.
mike regish
On Sat, 15 Nov 2003 13:40:58 -0600, "Roger Tracy"
Yes. I go by tach time anyway and can peg fuel consumption
pretty close.
Spoken like a high winger. For us low wing types we have to know how
much fuel is in each tank. Since climb, cruise, and descent all use
different amounts of fuel it is hard to know how much is left in each
tank. Sooner or later we come to the point when the POH says switch to
the fullest tank. We need the gauges to know which one that is.
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Mountain flying instruction: McCall, Idaho, Colorado too! [email protected] General Aviation 0 March 26th 04 11:24 PM
Progress on Flying Car Steve Dufour General Aviation 5 December 19th 03 03:48 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
the thrill of flying interview is here! Dudley Henriques Piloting 0 October 21st 03 07:41 PM
