#11
On Thursday, May 24, 2012 10:17:13 AM UTC-6, Bart wrote:
On May 23, 10:47*pm, bumper wrote: There are a few reasons that one PF equipped aircraft might "alert" while the other conflicting aircraft doesn't. In a perfect world it should be a two way street. However, the installation or placement of an antenna for transmitting is more critical than that for a recieve antenna. If glider #1's PF antenna is installed less optimally than glider #2's PF antenna, it may well be that #1 gets the alert while #2 does not. As #1's poor antenna install may receive marginally well, but wastes transmit power due to a high SWR or a null due to blocking structure. Oh. PF uses one antenna to transmit and another to receive? Bart PF uses FLARM port A to transmit and receive. It uses FLARM port B to receive only. There is a third port for the transponder/ADS-B receive function. And the brick adds a fourth connector for remote GPS antenna. On Thursday, May 24, 2012 10:17:13 AM UTC-6, Bart wrote: On May 23, 10:47*pm, bumper wrote: There are a few reasons that one PF equipped aircraft might "alert" while the other conflicting aircraft doesn't. In a perfect world it should be a two way street. However, the installation or placement of an antenna for transmitting is more critical than that for a recieve antenna. If glider #1's PF antenna is installed less optimally than glider #2's PF antenna, it may well be that #1 gets the alert while #2 does not. As #1's poor antenna install may receive marginally well, but wastes transmit power due to a high SWR or a null due to blocking structure. Oh. PF uses one antenna to transmit and another to receive? Bart Here's the excerpt from the manual: "BRICK has two separate FLARM radio transceivers: FLARM A is used to receive and transmit and must always be connected to an antenna; FLARM B is only used to receive, an optional antenna may be used for better reception performance." Its the same for both portable and brick versions. Although the portable only has the FLARM A connector with reverse polarity (via a staked on connector adapter". With the 2 antenna setup in use there could easily be regions where you have receive coverage but not transmit coverage. -Dave |
Avenal Contest, Still Needs Tuggies | sisu1a | Soaring | 0 | February 27th 09 05:06 PM |
Avenal, USA Contest Maps 2007 Downloads | Mario Crosina | Soaring | 0 | April 20th 07 07:45 PM |
Avenal Contest | [email protected] | Soaring | 0 | April 12th 07 04:55 PM |
Avenal Contest | [email protected] | Soaring | 0 | April 12th 07 04:20 PM |
33rd Annual CCSC Contest, Avenal USA | Mario Crosina | Soaring | 0 | April 9th 07 03:59 PM |
