Angle of incidence
Old May 29th 12, 10:14 AM posted to rec.aviation.soaring
Z Goudie[_2_]
Default Angle of incidence
At 07:16 29 May 2012, BruceGreeff wrote:
Have learned to bring the big Kestrel in a lot slower and the landings
are a lot less exciting. Still have a way to go. She can be landed in an
incredibly short distance if you have that approach speed nailed.
In my case the magic number is 100m later - and that is with landing flap
and half airbrakes.
At low speed the ailerons are less powerful, but a little airbrake
increases effectiveness by diverting airflow over the controls so you
should have more than enough control - you are trying to fly straight -
not do aerobatics.
In my 19m Kestrel used to use full landing flap and full negative flap
(separate levers!) More than enough drag from the inboard flaps plus
brakes and plenty of roll control from the outers until it came to a halt.
Old May 29th 12, 06:42 PM posted to rec.aviation.soaring
On Monday, May 28, 2012 1:16:31 PM UTC-4, Roel Baardman wrote:
First of all: thanks for all the replies!
I find it incredibly interesting to ponder about these subjects, so more info is
better :-)
I also like the Ls-6 story!
My tendency with the B4 is to approach with too much velocity, often 100 km/h.
This gives me the feeling I have proper aileron control, so it's intentional.
When I approach the deck and slowly start to bring the nose up, I encounter the
ground effect that the B4 has. I either float for a long time before touching down
with a two-point landing, or I make a touchdown on the main wheel only (sometimes
with a slight jump after that).
What happened yesterday, was that I was so busy compensating for crosswind (I
don't want to have a traversed landing), that started floating again and gained
some altitude (1 meter roughly).
Knowing that the fault is probably in the velocity, I approached the instructor to
learn from his B4 experience.
I agree that the B4 is very friendly and benign. I will put effort in bringing my
approach speed down to 90 in the upcoming flights.
I would guess that you probably are not using a lot of spoiler in the round out/ flare which extends the time and distance needed to shed enough energy to land. If this sounds right, try more spoiler on final and leave them out using elevator to round out. Start the round out a bit higher to allow for steeper approach.
Good Luck
UH
Old May 29th 12, 06:57 PM posted to rec.aviation.soaring
Roel Baardman
On the contrary: I'm using full spoiler lately. Part of my excess in speed comes
from approaching high and putting the nose in besides full spoilers. The speed
doesn't bleed off very fast when I'm level.
Old May 29th 12, 08:31 PM posted to rec.aviation.soaring
noel.wade
Roel - I don't have any experience in a B4 so please take this as
general commentary and something to consult on before trying in a
B4:
With all the ships I've flown (both metal and fiberglass single-
seaters), the way you know you've got the right approach speed is that
when you start your flare/round-out you can bring the nose up beyond
"level" without ballooning (this leads to a decent two-point landing
or touching the tailwheel slightly before the main wheel touches
down). If you are already pulling full spoilers and you cannot bring
the nose a couple of degrees above the horizon without ballooning,
you're probably approaching too fast and you might try incrementally
decreasing your approach speed by 3-5kph (2-3mph) until you get less
float and a smooth touchdown with 50% to 80% of your spoilers deployed
(there are a couple of ships out there that benefit from closing the
spoilers most of the way just before touchdown or they kind of drop
through the flare; but again I don't know enough about the B4 to
comment).
I prefer a steep approach (for safety, in case of sink or a big wind-
gradient), and have found that sometimes you have to consciously fight
the urge to dive for the runway. It takes a bit of training to pull
spoilers *earlier* during the base-to-final turn or just after lining
up on the extended runway centerline (i.e. just as you get onto final
approach), but I find that pulling spoilers a little earlier like that
helps keep me from building up speed as I keep my pitch attitude
slightly flatter and don't dive for the runway (and if I do, having
the spoilers out BEFORE I pitch down helps the airspeed from building
as quickly - pulling spoilers *after* you dive doesn't tend to slow
you down dramatically until you get into the flare/float).
Hope this provides some food for thought!
--Noel
F8 Crusader Variable Incidence Wing [email protected] Naval Aviation 8 August 18th 09 01:57 AM
Skybolt Tail Incidence Question Scott Rodriguez Home Built 1 November 20th 05 07:44 PM
Skybolt Tail Incidence Question Scott Rodriguez Aerobatics 0 November 4th 05 04:16 PM
Another angle... tongaloa Home Built 0 February 27th 04 11:13 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
